All Forum Posts
961 owners
Perhaps the moderator can assist with this. As I understand it from the factory there are some 1000 961's registered. Presumably most are in the UK. If so how many UK/European 961 owners are NOC members on this forum.
Was it a scam?
There was a strange message posted this morning regarding a racing Norton in Australia with a huge amount of spares which was to be sold.
The message does not appear any more. Was it a scam?
ES2 frame/gearbox
Me again. In removing the lower bolt from the gearbox I see that there is a gap between the gearbox and the frame and a further gap between the frame and the detente position of the primary chain-case inner portion. Is this normal?
Headlight brackets
A friend of mine brought some headlight brackets to show me, cast aluminium, with the oval Roadholder badge on the upper part rather than below the forward protrusion of the steel examples.
Who knows which model they are from?
Crankcases
I purchased a Commando MK3 1975 (in Bits) The engine had been dismantled as one of the con rods had bent.The crankcases have
Records
Just a note to thank Dave the records officer for his rapid response to a question relating to the history of my machine.
I am continually impressed by this club.
ES2 gearbox bolt
My parts list for 1955 shows on plate JX item no. 65 the "gearbox bottom bolt and nut" given as part no A2/312.That is for a solid frame. It does not show anything on plate JY - the swinging arm version.
