All Forum Posts
Front wheel offset
The front rim on my 1963 frame is offset to the right, I only noticed it recently after some years wondering why the bike didn't steer as perfectly as I expected. I fitted a TLS brake c/w hub some years ago from Norvil (works well).
Pilot jets
Wrt Lance Crossley's Tale of Mystery and Ineptitude in RH336 - "I don't know what I would use to increase the pilot bush by .002". I suggest consulting any good old engineering reference book.
Messages
Is it just me or is the list of messages on the right no longer putting them in date order?
Magneto malarky
I have a mid 1930's BTH singles mag that worked after a fashion till i cleaned and adjusted the points and earth brush. The gap was larger than it should be ,possibly 20 thou. Now its 12 thou the spark has gone.
Manx fairing question
Two days ago I visited an old friend to ask him about my recently aquired 350from -59, which he raced quite successfully back in the sixties. When he looked at photos of it, he noticed that it missed the fairing.
Navigator speedo
Hi I have been riding the navigator quite a bit and the speedo seems to be working ok but have just noticed that i have only done eight miles ?Does anyone know where you can get a replacement unit as to strip it down to clean the trip numbers mean
Tank painting?
I have started stripping the tank of my 1962 Norton Dominator. I thought it would be like doing my series so started the process early with the star Chem Synatrip. It was like washing cream out of bowl. Answers why it was a *&%^$ job.
Dominator rear hub
Hi,I'm getting very close to getting a project bike back on the road but am stuck with the rear wheel, I think I need the below but I'm not 100% sure.I Have:Rear Hub - Laced into a new rim.Rear Sproket/BrakeSpindleStub AxleI Need:Brake Plate - And
Correct carburettor
I have '54 ES2 which acording to Haycroft should be fitted with an Amal 276AU. It is actually fitted with an Amal Monobloc wiht the numbers 376/253 stamped on it. So, some questions:
Oil level
I have just changed the oil in my 650SS.
What is the correct oil level in the tank. I run it half full, but don't have a level transfer on the tank.
Is this correct ?
Weave issue
In an effort to get the most out of my tyres I fitted a new 100-90-18 Roadrider to the front of my Fastback and the similar sized front that came off went on to the rear to be "used up" I have a WM2 rim on the front and a WM3 on the rear.
350T
I have started a restoration of a 350T. I have posted a picture of the frame to let people see the shape of the frame. The top frame tube and front down tube are excatly correct. You would think someone bent both.
