When I aquired my 1952 ES2…
this is photo of a bottom…
this is photo of a bottom bolt in a laydown g/box cant remember if it was of my es2 or 19s frame though.
Attachments image1-jpgl-jpg- Log in to post comments
Fascinating John. That's…
Many thanks, Barry. The pi…
Sorry Barry. I've looked…
George another photo not s…
George another photo not saying yours is same just showing how the bolt fits.
Attachments image1-jpgh-jpg- Log in to post comments
Photo's come out a bit di…
must admit George it isnt…
must admit George it isnt one of my better photos just trying to show how the bolt fits if its same as your. Baz
I'm very grateful for you…
In 45 years of owning and…
In 45 years of owning and running 6 Norton singles I have never found the need for a clutch extactor but you will need a sprocket extractor. Will be in my garage later today and will measure the two gear box's. John
The '77' gearbox marked…
The '77' gearbox marked 'GB8' has a lower width of 3 5/16 inch and a kick start shaft length of approx 1 7/8 inch.
The ES" box marked 'G102' is 3 1/2 inch wide with a kick start shaft length of approx 2 3/8 inch. John
Brilliant. Thanks John.I'…
Just been out to the garag…
Hi George. My sprocket rem…
Hi George. My sprocket remover is a two leg type inherited from my dad, a life long motorcyclist, so is older than me! I have found once the clutch holding nut is remover the whole assembly just slides off the spline. As for running the twin gear box, no problem other than he kick start fouling the silencer. In fact now I have changed it over to the correct box I find it not as precise as the twin one which was no doubt why it was substituted in the first place. It had been attached to a side car for some of its life therefore the gear box would get plenty of use. John
Thanks John. Your help has…
I'm sure the numbers on t…
I'm sure the numbers on top of the box mean something but I have no info. Hopefully some one reading this thread may be able to help. John
Hi John - hope you're sti…
Hi George. Will do this to…
Hi George. Will do this tomorrow morning but which width are you referring too? If its the top fixing width it's the same for both gearboxes. John
You've answered it John.…
