All Forum Posts
650 pistons
I have just fitted the pistons to the conrods of my 650. The small ends needed heating for the gudgeon pin to fit throughhowever the pistons are loose ie slide in easily and rotate. All items are new and pistons standard bore size.
Thank you!
Just a brief note to thank Mr Grimmett for his email received today. A most satisfactory conclusion! (Supercar fans!)
Lockheed caliper
Hi. I am trying to replace the seals on a Lockheed calliper fitted to the front original disc Mk111 Commando. It looks to be a Norvil Upgrade but I cannot be sure. The number printed/stamped is 10K9DT.
Sticking gears
I know clutch drag has been discussed to death but I'm not convinced that my 55 ES2 has clutch drag. It is difficult to get into and out of 1st gear yet, on the centre stand, the rear wheel is not dragged round by a sticking clutch.
What gearbox?
I'm new here and am going to recreate a 1952 Manx Norton based on the long stroke 500cc DOCH engine. I will not be racing it so competition wise is not important.
1935 ES2 oilfeeds
Hi, I have a nice oily rag es2 but cannot find out which oil pipe goes where!!! It has one block to the rear of the timing case with two pipes soldered in. Which is the feed and which the scavenge? Cannot figure it out for the life of me!
The Forum
Why not rename the 'messages' section as 'forum' and make more of a song and dance about it on the site?
Model 50
My recently purchased m50 appears rather slow compared to the one I had in 1977.
I appreciate that time plays tricks with the mind plus I am porkier than I was then,however I am disappointed with the 46mph cruise.
