All Forum Posts
Wheel Alignment
Hi
Just done a wheel alignment check on my 1974 Commando 850 and discovered the front and rear wheels are not parallel.
I haven't noticed any obvious handling problems.
Re: Identity
I have an ex-race rolling chassis which has no frame number, the original lower left tube had been replaced with a section to carry oil for chain lube, and with it the gusset plate had been changed.
ES2 Cafe Racer Project
I have an ES2 1953 which has a decent engine, gearbox and frame. I would like to restore the machine with a cafÃ? racer look. I wondered if anyonecould give meadvice regarding suppliers for tank/seat and other parts.
A big thankyou
I posted this in "Off topic" but as you have to Log-in for that heading to come up (for some reason) I felt it would be better posted where I had received al the help.Just thought I'd post a big "thank you" to all the club members who have so gene
Clutch lift
Recent data on the variety of clutch spring lengths lead me to dismantle my clutch which is 1955 laydown box. The springs were more or less as quoted for length and I reassembled and used by dial gauge to check for equal lift.
A big Thankyou
Just thought I'd post a big thankyou to all the club members who have so generously and patiently shared their knowledge with me and helped get my '55 ES2 into tip-top condition.Thanks yo you I now have little or no leaking from the p/chaincase; g
tank re-spray
looking to get my commando tank and side panels re-sprayed as they are starting to look a bit tatty. I live in north west, Cheshire. done a quick search in the services section and a company called "farrout paintwork" in congleton came up.
PW3 Camfshaft
I have just stripped my Combat motor down and the camshaft looks fine, but I'm considering fitting a new PW3 camshaft. I would be interested on members views to see whether its worthwhile.
