Transfers
Our wideline Featherbed bike used to have an 'Unapproachable Norton' transfer on the rear mudguard like that shown on the primary chain cover of Mike Pemberton's bike on P38 of the latest 'Roadholder' magazine.
Afternoon all. I've got a 1972 Combat 750 Interstate that I find uncomfortable to ride, the problem is annoying enough for me to be planning to sell it. It has non standard bars ( slightly lower ) and standard pegs.
Does anyone know if these `fuel catalyst octane booster tablet/capsules` work? They are supposed to have a life of 250,000 miles,but do the work?
Wanted Norton Manxman 650 Silencers Partsnumbers 23174 RH & 23437 LH Phone 01430 430831Ms Anna J Dixon Orannajeannette@btinternet.com
Does anyone know if the cigar shaped silncers as fitted to a '59 '88' are still available please, i have only seen the later ones which bump up at the top just behind the front pipe connection, thanks
Thankyou to those who assisted with my engine queries(tappet settings), I think it is oil tight enough now too.
Millers Classic Oils Now Awared the top Approval By The FBHVC See WWW Millers Classic Oils .Co.UK So Get THe Best Oil In Your Norton Classic Motorcycle , I Have Used It for the past 3 years Now And I am very Happy with it Please Note OLD Classic N
Any advice on my 'sticky forks' ? After a long total rebuild (32years, don't ask) I have finally got my Atlas working again. I bought new fork stanchions, bushes and seals a while ago (15yrs+)and fitted them.
I've had my ES2 for about a month now and with a bit of advice from Mike Pemberton have hopefully sorted the oil leaks from the pushrod tubes, although I have had difficulty in finding out who can supply seals of the correct type but silicon seams
I have acquired a fully restored 1948 ES2 but am having some problems and hope people more familiar with Nortons will be able to provide some advice.
At the risk of alienating other lightweight twin owners, I wonder if it's worth the cost to change my leaking, smelly Monobloc 375 for a new Amal Concentric MkII?
Hi,can anyonetell me whatthe correct speedo is for a 1960 Dommie 99.Chronometric and 0-120 mph I guess,any other information would be greatly appreciated.
Thanks Keith
Help needed to solve insurance problem
I have built (nearly)my Commando in the flat where i live!!!
Problem being, to put wheels etc on to start it up I will have to get it into the garage.
hi,my 1953 es2 has decided it will only get 4th gear if i tap lever gentlyUP, first and then maybe it will go in with a prod down.Sometimes i can get 4th if i leave it in 3rd and prod away after a short time till i get resistance,bit like lucky di
I have just got a Wassell Power Box as part of the upgrade to 3 phase - does anyone know where it would be best to mount it it? "Not in an enclosed space" says the litaerature, but I want to keep the wiring as short as posiible really.
Hi - I am just about finished restoring my 850 Commando and need some help with the side panels.
1. How is the Dzus clip fix to the battery side panel, is it pop riveted?
Well,have to say i didn`t expect such a fast response from so many people.I will follow up leads.
As i thought,a great club.
Hi there, I applied petseal to tank, it was clean and dry. The seal took quite a time to dry (several days).
Hi all,i have just bought 1953 ES2.My first classic for 10 years.Where can i get cables and a parts list from? i have looked on Ebay ,no luck.
Great club by the way,looking forward to meeting some of you when i get some cables,haha.
Hello All,
The twin carb's on my 54' Domi racer are causing a few problems. The slides close easily when the engine is not running. With the engine running, any light opening of the throttle causes them to stick open.
Just had some machine dating info returned from Chris. On the sheet my Model 20 came from the factory with a panel mount instrament and a dyna gearchange.
I am restoring a 1966 650SS dominator and I am looking for the orignal paint colour code for the petrol tank. the colour I am refering to is the same as the 650SS featured on the NOC website under model's ( dark graphite silver metallic).
did the featherbed bolt up framehave any weakness or was it just ease of production that caused the introduction of the all welded frame and what year did this occurr please.
Folks - I have a decision to make, and I would apoppreciate the views of anyone who has had similar experiences of their bike.
Can anyone advise if it is common practice machine down clutch pressure plates?
Thanks.
where can i find it on a navigator mine is powder coated over
thanks in advance dod
Hi all,
I'm building my first ES2 bike and need to set the valve lifter.I have looked through instruction/guidance books but can't find any information.
Does anyone have any guidance please?
Thanks, Rob
Can anyone throw light on the subject of Dommi fork oil seal holders ,I have just got a pair of new ones only to find the length of the threaded bit on them is10.27 mm and the ones I removed from my forks (7 3/8 short road holders) are 7.86mm so w
Hi all, not sure if this is in the correct place. I have a bitsa. Wideline with atlas engine. I was wondering if anyone knows what my front brake was from? Thanks Carl
