Axial play on dynamo
Last weekend, a strange noise occurred when I closed the throttle of my Model 50. It was a strange whining/rubbing noise. Like something was spinning on an axle or grinding against something. Best way to describe it would be the sound of a bicycle rim brake when the two blocks hit the rim and start squeaking with a sort of resonation in it. It seems like the noise was coming from the primary gear, from the oilbath. But with the noise of the engine, carb and exhaust, combined with earplugs and a helmet, that diagnosis could be faulty.
It stopped at idle and then occurred sporadically when I decelerated, or sounded constantly for a while... or not at all. I feared the crankshaft sprocket nut had come off, but did a little dance when that wasn't the case. The clutch was also fine.
As I did the timing the weekend before, the most likely suspect now was the MO1 magdyno. I've never liked the sharp tap you have to give the magneto sprocket to seat it on the conical shaft. After checking, the recently tensioned (without tension) timing chain was now slack again and there was quite a bit of radial play on the magneto shaft. A spinning bearing could explain the sound I guess. The most likely suspect is the insulating washer, so fingers crossed it will be that easy.
But when I removed the E3L dynamo on top, I found that one had quite a bit of axial play, yet no radial play. Just to make sure I get the terms right: when holding the gear, I can't move it up and down, but I can push and pull it a little in and out of the housing. Could someone please tell me if this is this normal or do I need to a bit of shimming or adjusting?
A bit of a long story to get to the dynamo question, but you never know if somebody recognises the explained sound at the start of this post and will say: 'You're looking for something completely else, have you checked your left footpeg?' or something more sensible. There's no Lucas manual (that I could find) that even speaks of shimming. It's all about the electrical stuff.
P.s. I put this in GENERAL, as it's not really ELECTRICAL.
Cheers,
Tim
Noise such as you describe needs investigating further.
End float is axial movement and needs to be kept in check to avoid damage.
For peace of mind strip the component and look for witness marks such as shiny metal or metal dust is an indicator of too much end float, check the bearings for wear and or lack of light grease within.
Either the bearing has come loose in its housing, or the bearing is wearing out, allowing the end float as described.
John
Thank you both. The sound really does need investigating. Well, all sounds do, don't they?
Regarding the dynamo: the bearing can slide in and out of the housing. There's a cover over it, that stops it from going further. A small ring in the cover would clamp the outer bearing race. I was in a hurry last night and just had a quick look, but it could be there's already a small ring there. In that case, I think I'll probably use a bearing bonding agent to keep it in place. I've cleaned the test of the dynamo and found no further trouble, though I might change the brushes, as they're quite on their way.
As the bearing is loose in its housing, it could theoretically be rotating the outer shell, causing the sound. Especially as there's no chain pulling on it. Still, I'm doubtful it's that loose, that it would do that. There's no radial play, just not a tight fit.
As for the magneto: I think I have to remove the complete platform to be able to dismantle it. But there are some oil pipes in the way and I don't fancy draining the oil to disconnect them. Might have time for that fiddly job tonight. I still have a hard time believing that that sound could come from such a small bearing, but it's the most logical culprit, as there's a lot of radial play.
Just to be on the safe side, I'll take off the clutch too and check it, although it works perfectly and doesn't show anything strange on the outside. Gives me the chance to fabricate a clamped felt seal on the inner cover of the oil bath.
Luckily, it's raining all week, so I'm not missing out on much!
Well, hopefully...
The cause of the axial play on the dynamo is still a mystery to me. Might have been there all along. As the bearing has a cover over it, I guess it needs to be clamped to be really secured into place. Since there was no radial play, I didn't resort to bearing bond. I just took an old magneto insulating washer, cut of the lips and used that to fill the space between the outer race and the cover to create a good clamping fit.
The magneto bearing had a lot of radial play and I think that might have been my own fault for not checking the chain for a tight spot. I was so focussed on not having the chain run against the housing, that I forgot that while running, it tightens itself on the side closest to the housing, while the other side it slung inwards. It can (and should) have more play than I anticipated. Running the magneto on a drill (which is similar to idle), I couldn't replicate that nasty sound, as I just didn't make enough revolutions, but strange sounds could be heard nevertheless. So, I'm quite confident that the magneto bearing could be the culprit, spinning freely in the housing.
The radial play was a quick fix, with a new, thicker, insulating washer. Well, two, as the first one shifted when I hit the bearing in place. Removing the bearing after that proved a new challenge that involved some strong words, followed by an even stronger brew to do what I sould do more often: think before I do.
It's all together now and there are no more strange noises.
You could audition to be a member of a Tremeloes tribute band singing "Silence is Golden" using your skills!
