All Forum Posts
Paint
Hi, could someone please inform me was the 650s slimline frame stove enamelled from new.
Regards,
Kenwyn.
AMC clutch
Good morning
Does anybody know what the correct length of AMC clutch springs should be? (or at what point should they be renewed?)
Repairs in Northumberland
My 750 Commando has sprung a leak from the cylinder base which I'm not confident of repairing. Can anyone suggest a dealer in Northumberland who is able to tackle this for me? (Peter Elliott is greatly missed).
Best Regards
John
1957 ES2 in red
Hi Guys, I am about to start a restoration on my 1957 ES2, it is red and as I have seen Dominators of the same year in red could this be its original colour?
WD 16H
On YOUTUBE there are three excellent war time films on maintaining, servicing and riding the wd 16h. In one of the close up shots of the engine unit there is, what I presume to be, an earth wire from one of the magneto end cover fixing screws.
Sprocket puller
Quick question - will the socket puller sold by the club and noted as "pre Mk3" fit a 20T engine sprocket? I'm having trouble sourcing one for my '55 ES2 George
500T oiling
hi iam trying to find out if the oiling was altered on the 500T by blanking the feed to the barrel skirt so allowing more oil to the big end i have two timing side cases one 1950 one 1951 one drilled to allow oil one blanked also the oil way in th
Restoration
Hi all I am new to Norton bikes and could do with someone pointing me in right direction about getting some work done, I have a 1950 model 7 that one is ok but I have a 1960 Dom that needs bringing back to live, and I have a race bike it's got a M
Tool kit
This is my firstgo at attaching Pictures so please forgive me if it fails. This is as most of you know an illustration of the wd 16h tool kit. Item 20 is specified as 1/8" x 1/4" Box spanner.
Triton registration
Firstly hello to all as a returning member. I recently aquired a Triton from South Africa to go with the 650ss Dunstall Dominator in the stable. The frame is a model 88 1954. The engine is a T120R unit motor June 1970.
Mikuni carb.
Hi. After much cleaning, tweaking, popping and swearing I am considering fitting a single Mikuni to my MK111. I have one fitted to my 750 and it startsand runs fine with little or no maintenance.
