ES2 gearbox bolt
My parts list for 1955 shows on plate JX item no. 65 the "gearbox bottom bolt and nut" given as part no A2/312.That is for a solid frame. It does not show anything on plate JY - the swinging arm version. Can I assume they are the same?The threads have stripped at one end so I need a replacement. If that proves difficult would a standard high tensile bolt suffice?Thanks for any help.George
Thanks Michael. I checked that as you suggested but it looks nothing like the one on mine. Without rushing out to check I'm pretty sure that my centre stand spring is connected elsewhere other than to the gearbox bolt.I think I'm in for £20 or so from Norval.George
