All Forum Posts
Oil leak
Hi can anyone help went out on the navigator on Sunday and am getting an oil leak from the gearbox drive sprocket .I have ordered up a sleeve gear oilseal .On strippin the primary case off of the engineI find there is an oil seal that seems to be
Pinking
Sounds like I have a wee issue with "pinking"
How far retarded has anyone gone with ignition timing to sort pinking?
how many clutch plates
can any one tell me how many clutch plates i need i am puting new clutch plates on my 1951 plunger model 7 i took off 6 plain plates and 5 friction plates i am using my old plane plates as there is nothing wroung with them but now reasembling i ca
Lost marbles
Hi all,I fear I have lost mine, I purchased a norton without docs or any real ideas to its origins and I am now hoping you guys will put me in the picture about it please.
1962 ES2 oil tank
Hi All,
A friend recently purchased a '62 ES2 & it is missing its oil tank. His parts list has not arrived yet & I was wondering if anyone could tell me:
A) what is the part number for the correct oil tank
ES2 valve clearance
Sorry to resurect an old subject but valve (tappet) clearance on the iron head ES2 is given as 'pushrods free to rotate' on the compression stroke. How free is free? I have always set mine so that the pushrod can be 'spun' on the follower.
Custom mufflers
HelloDoes anybody have an idea, where I could get custom or aftermarket mufflers for the Commando 961?The left one of my original and very tame stock pipes is quite tight (much tighter than the right one).I also have the accessory long open muffle
Interpol tank
I am thinking of selling my 1974 Commando Interpol tank, firstly I would like to see what interests there is for these tanks, it's steel and good condition no rust or dents, no radio box the penials (think they call them that ) have been filled in
Clutch trouble
Hi can anyone help Have got my 1962 Navigator back on the road it sailed through its MOT no problem .Well went out for a run all going well untill i lost the clutch .I thought it was a broken cable and managed to limp home .When I looked the cable
Side stand
once again i ask fellow members who own a 961 have any of you changed the rediculous side stand for one more easily useable aftermarket or any other, would like to hear about it.
