All Forum Posts
Side stand
once again i ask fellow members who own a 961 have any of you changed the rediculous side stand for one more easily useable aftermarket or any other, would like to hear about it.
ES2 pistons
Does anyone know the significance of the piston change between 55 and 56. What was the purpose? I have a 55 and need a new piston .
Crankshaft balance
I did a search here for balance factors for Atlas crankshafts. That's a lot of reading. I found a recommendation for a 73% balance factor and another one for 85% balance factor. No one else was willing to make a firm commitment.
Amal spray tubes
Hi chaps, I'm going to service and clean the Concentrics on my 1974 920 Mk2A and noticed that on the Amal (Burlen) website they show a special spray tube intended for 'later 850 Commandos'.
Parts help needed again
I am trying to find a couple of small parts for my 1954 Big 4. I am looking for (4) screws, J23 which is listed as B2/626 and crosses to the new numbers 021299 they are "spring cover tube (bottom)securing screws. This is on my roadholder fork.
Forks
Hi all I wonder if any of you experts out there know what forks are on my dominator 88 i thought they could be off a commando but not sure now thanks Simon
P11 high level exhaust
Recently purchased a P11 "work in progress" project. The exhaust's are new and shiny. Unfortunately they are rubbish. Whoever made them obviously never tried to see if they fitted. So, the question is, who supplies the best?
1930 16H
Hi all,as a new member , i am looking for advice and where i might
find a part, a valve casting that encloses the side valves. I have found
the square inspection plate ,gaskets and seals ,but no sidevalve casting.
ES2 featherbed air filter
I know this has been asked before, but has anyone ever seen an air filter for the featherbed ES2/50? If someone has one I could get some parts made if necessary.
The parts book suggests that it is attachedto a manifold bolt.
Oil consumption
Just for info, as the previous thread was closed by the Webmaster, my 961 has 3588 miles on it as of tonight, and has used no oil whatsoever since its first 500 mile oil change last Sept.
Oil in airbox
Having been advised to drain the airbox on my April 2015 SF following a 'good run' I'd be interested to hear from other owners about the volumes drained, frequency of draining and mileages done between drainings from other owners given the same ad
Tank cover
I have decided to find a tank cover for my still prisitine tank. Please advise how much and where I can one if anyone has bought one?
Roger
