Crankcase timing tool
I was just replacing the screw in the crankcase with a stainless one, when I wondered about making a timing tool.
I find a 3/16" drill sits snugly in the slot in the crank. Having a lathe, I was thinking of drilling the old screw 3/16" to make my own tool. As the scale at the window in the clutch case is adjustable, would my tool give me a more accurate 28deg. position,  then I could line up the adjustable scale for using a strobe?
Just check the scale in the primary case is accurately set (using a timing disc and a piston stop or dial gauge) Then use that to strobe the engine as normal.
You would have to check the slot in the crank is accurate first (using the said timing disc) anyway as it could be anywhere.
.. use a similar arrangement for timing. But as Peter said, you need to check with a timing disc and piston stop.
It strikes me as strange that Norton would go to so much trouble to machine a groove in the crank for timing if it wasn't accurate?
It is not unknown for the ignition timing plate to be out of kilter on some engines.
If you have the means the suggestions above will stand you in the right ball park. Its never wrong to verify previous established practices as often discrepancies are found.
Norton are not immune in this area for inaccuracy.
The factory drawing of the crankshaft shows the slot is at 28 degrees.
I have done just what you suggested and made a 'bung' with a hole for a 3/16 drill.
This then locks the crankshaft at 28 degrees, then you can check the scale in the inspection hole is spot on, as it mounts on slots, it could be out by a few degrees either way..
I think there's a tool available from AN but I centre the slot by eye. The 28° was checked years ago after balancing the crank, it was spot on. Also put a TDC centre punch mark on the crank as a reference.
On my Mk3 I use the crank slot to set the Trispark with the inbuilt LED, a very simple, accurate process. Never used a strobe to check, even prepping for a dyno run.
I marked 28°on the primary as the original scale was miles out. It's more likely this will be inaccurate rather than the factory machined crank timing slot as Peter Finlay suggests.
A lot of room for error with a timing mark on a 74mm removable rotor made by different manufacturers..
