Rockers - OHV or SV
Attached picture shows some rockers in my collection of spares. I have had a box of them sitting around for quite a while and know that they are not off any twin engine I have worked on.
Hi Can anybody point me in the right direction for a 16H kickstart shaft cover as mine hasn't got one fitted at the moment
Is it just an ebay hunt?
Stuart
Friday evening at the Begonia, and it's not raining!
My 1959 Model 50 starts first kick but stops after about 10 miles an won`t start again for several hours. Have cleaned the carb and points fitted new ht lead and plug. Any suggestions
Just wondering, does anyone remembers the dealer T H (?) Ashcroft of Thornbury?
This is my 1932 Big 4 I have restored.It was delivered with Bosch mag/dyno and 4speed TT footchange gearbox.
Nortonregards from Svein.
Hi, I run a 1938 ES2, and recently lost its spark. So upon resolution of said problem I also decided to improve the timing as the chain seemed very loose.
Has any member fitted the gold anodized chain th the 961 and if so size,cost, and where from?
Hi, any recommendations for the correct grade of oil and make for a 78 850 mk111, also any preference on the oil filter . having only just purchased the Norton and a fledgling to the british bike world . Many Thanks Andrew.
Hi just introducing myself to other members, i have just recently purchased two commando"s , one a 1967 commando with a wideline featherbed frame completed by JMC restorations, the other a 1978 Mk111 850 and enjoying every moment on it.
After owning '69 Bonneville, '67 and '70 Daytona ( and a few screaming Japanese 2 strokes ) I cleared out my collection ( with the exception of Lil Smokey RD125B ) in search of my dream bike - a 1973 Commando 850.
Not sure if this is the correct forum for this post but I need a little help please.
I'm about to start rebuilding my rather dillapidated 1961 (I think) Navigator and am casting about for the major missing parts.
Hi. I have recently bought a MK111 Commando fitted with Trispark Ignition. As the bike had been standing for a while i chose to service her which naturallyincluded changing the plugs.
Can anyone confirm wether a domed decorative rear wheel plate was fitted to the right hand side on my 1956 ES2?
Can anybody tell me if the rear brake on my model 14 project sould have a seven or eight inch brake and could anyone supply any dimentions for the rear wheel as i have been unable to find one so my next move will be to make one or modify a standar
Waiting for parts on other projects so have been looking at the jubilee, installed the Boyer and set the timing with a degree disc, loosely fitted new club wiring loom and got out wiring diagrams to work out what to fit where!
Hi everyone I have just joined and would like to make my presence known I have today bought what has been described as a late fifties dominator 99 which is 95% complete but in bits with a lot of solid original tinware that I will not be using as I
Hi, just replaced the front fork seals and checking for info on the front wheel alignment/fitment please. (71 commando - drums).
I have tried to fit one of these units to my 18d2 distributor with no success.
the v4 looks great. hope it does well. along with the new 650.
Hi All,
I posted this in the Website suggestions section originally, but thought it would fit in here as well:
My Boyer is about 35 years old and after a period of poor starting the spark appears weak. new 6v coils, copper leads, no resistor plug caps, N7Y etc.
When I added to a thread I wanted to quote a line of text from an earlier response and put the words in italics to emphasise the fact that it was a quote.
This is a job I can no longer avoid.
I have been quoted £70 by a local motorcycle dealership.
Hello, for my project I?m looking for a kickstart lever for a Sturmey Archer CS gearbox. It?s the curved one like in the picture attached. If someone might have one for sale I would be happy to hear from the person. Thanks
Hello All - Does anyone know what sort of signal I should be getting from a Type 5PU reluctor/pickup unit ? The unit is paired up with the AB11 Amplifier with yellow paint panel and two 6V PVL (German) coils in series.
The grey face magnetic speedo on the Atlas needs a service,There are cheap pattern replacements on the market that are a fraction of the cost of the service, has anyone tried one?.
Can anyone pleasetell me where the votage regulator on a Dommie 88 1955 is mounted I got the project in bits so did not see it come off
