Hello,
Here I am finishing up a normal service to this nice 1949 ES2 and although it starts right up, it will only remain running if I cover up with my had the carb trumpet.
Tried alterning all external screws adjunting the air needle but no luck.
Spark plugs in on the dark side.
Any clues?
Cheers,
Paul.
Remove the jet block and c…
Previously David Cooper wr…
Remove the jet block and clean the pilot galleries. That's how mine behaved and was completely cured. Getting the block out needs a mixture of care and brute force. I think there was some post about doing it without damaging anything a few months ago.
Thanks David. I thought I had cleaned up everything but looking at my photos, looks like the one thing I did not remove was the air adjuster.... will search for the post you mention.
Cheers,
Paul-have a look at the Am…
I'm sure that David is co…
I'm sure that David is correct in his assessment of cause and cure. I always place my bodies in a small bowl and pour a kettle of boiling water over them. The jet block can then be removed by tapping on an upside down hammer handle or similar.
It shouldn't need too much force and as David indicates, the block is quite vulnerable (it's actually a three-piece soldered brass construction).
The alternative is to ride in an ex-army greatcoat. They spend most of the time being sucked into the inlet !
Thanks David/Richard. Yes,…
Thanks David/Richard. Yes, I dismantled the carb although I did not go all the way since it seems pretty stuck.
Check out the jet's! incredible. Amazing it even started.
Although it starts right up and it idles.. I am getting serious backfires coming out of the carb!.... small flames!
after a good clean........
Hi Paul, Next task check t…
Hi Paul,
Next task check the valve clearances. If the inlet is being held slightly open when it fires it will do what you describe as well as spitting back.
If these are fine check the timing but if this is right a compression test might be in order.
Jim
Previously jim_royce wrote…
Previously jim_royce wrote:
Hi Paul,
Jim
Hello Jim, I had done all the homework before, timming, valve clearances, point gap, spark plug...
This bike had a rebuild engine a couple of years ago with almost no use, but here the fuel is very poor and when left standing, it becomes a very thick glue! blocking pretty much everything.
Will give it a compresion test to see what comes up.
Thanks.
Thanks David/Richard, look…
Thanks David/Richard, looks like the internal block from the AMAL was also pretty blocked. It was difficult since I was worried to break or bend the bronze part, but boiling it in very hot water did the trick.
After polishing it, it was a lot easier to place back on to the aluminun carburator.
Started her up and she idles beautifuly. Gather all my other Amal carburators will be needing this service too!
It would be a good idea to…
It would be a good idea to get a gauze flame trap on your carb in case it spits back when starting. My WD16H had just a bell mouth, but after it caught fire twice when starting I fitted one the same as my ES2.
Attachments DSCF0044%20crop.jpg- Log in to post comments
That carb really was very…
That carb really was very very bad. Was the mouse still nesting in there ?
There is quite a lot of wear to the slide guide on the jet block. It might not be a bad idea to include a new one the next time that you're ordering spares. To be honest, I think that I'd be looking for a decent spare carb.
Here is a video of the bik…
Here is a video of the bike starting right up.....
https://youtu.be/3DbLP7RlcQk?list=PLyZw58tWP1Si9O0KkwfndXFEGEmcsb1Uq
Cheers,
Previously Paul Greene wro…
Cheers,
Sweet as a nut.....
