Primary Chain Tension
I note on George Cohen's web site that he advacates running primary chains with 1 to 11/2inch slack. (3/8 to 1/2inch normal) Anyone with any experience? John
The previous owner of my "54 ES2 crammed the timing case with thick grease - presumably to queten a sloppy chan which I hve now adjusted.
Take delivery on Monday of my new Dominator. Will do a write up on how its rides etc weather permitting!!!!!
Somebody knows how I can view my private messages on this board?
Fritz
I removed the oil tank from my 1955 Model 88. Under the bottom, there are two bolt mounts through the oil tank platform, and another into the side of the tool tray. Oddly, mine has one bolt, and a stud with a nut.
I have just joined NOC and thought I should introduce myself!
So, hello, I am Kevin from North Cumbria. I have a 1962, 88 Dommie and have owned her since April.
Hi everyone finally managed to get an original slimline mudguard blade
quick question does anyone know a supplier for the bridge stay / black stays?
Cheers,
Tom
Hi - hoping for help to source a crank assembly (fly wheels and con rod) for my 1936 18T.
New or used. I have located three 2nd hand sets now - all cracked!
Wheels are 1" thick, 8" diameter.
I'm booked on the rally and now need to sort my accommodation out. Ideally I'd like to stay in one of the 'Luna' mobile homes but I'm going on my own andyou need to book them as a 3 or 4.
Could anyone offer general advice on proccess and product for lining of petrol tanks against the dreaded ethanol please.
Sholto
Does anyone know the email address of Fred Williams the bloke who makes mudguards
This might seem a strange request but the bike I'm restoring I have not seen it build up only in boxes and want to know how the tool box fits I have three parts a lid,case, and an oblong plate with three holes in this is the part I need to known w
Hello all, just signed up after recently purchasing an old 1960 Dommi 88 from a mate of mine, he has had it stashed away in his shed along with various other bikes for years.
Hello Chaps, I want to replace the 'O' rings on the swinging arm pivot end covers on my Mk2A (one with a grease nipple for sae140 oil).
Given that a Dave Taylor headsteady is a "good thing"are there any issues about the engine being 1/4" off set to the left, is there any problem about running out of adjustment, general lack of room or any thing like that?
My 1951 ES2 has what might be the original saddle plus a modern replica and both have been installed with various springs, hardware and brackets.
I'm looking to replace some of the very corrodedshrouds on the plunger spring units on ES2. Does anyone know where I can source some originals in good condition or failing that, quality replacements ?
Quoting from RH March 2015, Tim Harrison wrote;
"The democratic foundation of this system is that every member who is physically able can attend ...."
I'm pretty sure I have the wrong clutch cable as there isn't enough free cable to attach to the actuating arm, however even if there was I'm not sure how to at
Gents,
A friend of mine is shipping his 1958 Model 50 350 single overseas and needs the dry weight but cannot find it on the internet. If you happen to know that would be appreciated.
Best regards
Dave
This was recently sold on ebay, the open end is 1" Whitworth I believe. Is this for the fork head race adjuster nut?
Stan Dibben on sidecar racing:
ooh eck wonder what this is all about then. wonder if it will move over to bikes next.
I HAVE JUST COMPLETED A REBUILD ON MY SECOND ES2 AND HAVE HAD A DATING SERT FROM NOC, HAVE SENT THE REQUIRED COMPLETED FORM AND PHOTOS ETC TO DVLA ALL GOOD SO FAR.
hi please can anyone identify this electrica switch in headlamp, we need to order one as we think is faulty. part numbers , and where to order?
headlight-1-jpg
Hi ,have come upon a nice manx copy hub and rim in aluminium,as manx brake plate are hard to come by and very expensive what alternatives are there .the bike it will go on has Roadholder forks don't know if that makes a difference .
I don't know why the reluctance for change. The irony is, it'll never happen unless there's a majority of the 2% who want it to happen.
I propose for the 2% to vote in favour of an inclusive voting system.
I'm very new to the NOC and need help with identifying a 500 trials, is anybody knowledgeable on the pre production bikes,many thanks, Ken
Can I use my Atlas engine plates if I swap the motor for an alternator 88 (unknown year) or do I need to modify them somehow?
Hi Guys - I can't find the part number for the hollow threaded shaft onto which the primary chaincase retaining nut screws for a '54 ES2.
