All Forum Posts
K2F Dommie magneto
Having removed my Magneto I suspect my pick up ring is badly worn, I contacted Dave Lindsley, Magneto specialist, who quoted £350-£450 for an overhaul +vat+postage +extra for parts. This sounds quite expensive,
AMC kickstart query
Hi again everyone I have a slimline triton running an AMC box for which I have just bought a new kickstart when removing the old one I found a rubber seal wrapped around the spline that seems to be to big to do anything at all and it does
Electra query
Hello, Can anyone tell me about the bolts and spacers holding the top of the rear shocks and mudguard. Which side has the longer spacer? What length should either be? Why are they different lenghts?
All alloy push rods
HiI am building an engine for my Dommie 99 from a box of bits. In this box are many sets of push rods and I have attached an image of a set of all aluminium ones. I haven't seen these before and am wondering if they would be ok to fit.
Loose valve guide
I bought an Atlas head with a missing valve guide. The new guide will go into the cold head with light hammer blows. It is then tight and has to be pushed out again with hammer blows. The guide measures .499".
Tool kit
Hi guys
I'm back to Nortons after a 55 year gap and am the proud owner of a 1955 ES2. Forgive my memory loss but are all the nuts/bolts on the bike BSW as I have to invest in a new spanner set?
Dominator shocks
Does any one know the correct bottom bush length on the rear shocks for a 99 wideline frame dominator. I'ven been sold some that are 24 mm that the supplier insists are correct but they don't fit
