1955 Model 7 transfers
I see in the parts book these transfers are listed- A2/866, A2/867, A2/868 & A/869, can anybody identify these for me and advise if they are available anywhere? possibly under a later number?
Thanks Al
Thanks Al
I have bought some Miller's 20/50 semi synthetic engine oil for my commando and alsoDommie99 once run in.
However, talking to someone the other day I was told that the synthetic part would destroy the oil seals. Is this true?
I have a set of cast alloy wheels that i bought last year that as far as i can research are CMA or Cambray made.
I've taken the precaution of fitting an oil pressure gauge after my rebuild. I have new big end shells on a reground crank, yes there is a seal inside the timing cover and a new grommet on the pump.
Have realised my gearbox oil is low on my Norton model 50 350 1957 - I have some Titan ATF3000 oil in my garage, would this be ok or could anybody suggest a more suitable oil?
Gents
Could someone please tell me what size the nuts are for adjusting the points. Two tiny nuts, one the points themselves and the other its locking nut
Many thanks
Dave
Hi I am having the rear wheel rebuilt on the navigator, does anyone know if fhere is an offset and if so what it is .
Thanks Steve
Ive rebuit my laydown box with new bushes and bearings, including a roller bearing on the layshaft. It selects sweetly but jumps out of third when warm.
Putting the front back on I notice a loose bracket, My suspicion is that the taper roller bearings are spacing things out, is this a common problem with "improvements"? Can we still get the old ball and cup set-up?.
Hi everyone, Ive got a 31 model 18 engine which I need to get apart, its the first engine of this age some im taking it easy and not forcing anything. I need to get the large nut off on the right side. My question is 1.
Does anyone know what size the hammer drive rivets are,need to refix mine after a 25 year sleep in the box.
Are these the correct screws to hold the rear hub "cover" on with?
Hello all the rotor on my mk2a has the numbers 51 & 73 stamped on it does the 73 relate to manufacture year?
Hi all,
I purchased sight unseen what the seller said was a 1930 model 18 frame but I saw that it had 588 on the identification so I looks like its a model 19 frame.
Interesting announcement on the Andover Norton website - www.andover-norton.co.uk/News.htm
I've only just purchased my 650SS so I'm trying to sort out the little issues it has, one of the major ones is just how oval the rear brake feels. I've taken the drum off today but I can't hold it well enough to check how far out it is....
Am trying to rid the bike of various weeping, mistsand dribbles (!), worst of which is around the oil tank.
My 750 Commando has been misfiring and I initially thought the cause was fuel thus the carby was cleaned, checked and float level reset. On checking the plugs I discovered that they spark initially and no spark thereafter.
can anyone tell me the tollerance/slack in the magneto drive chain for my 1951 model 7 dominator, my book tells me it should be 1/8th of an inch for the cam drive chain but does not mention the magneto drive chain and to be honest the amount of ad
What's going on with people's avatars, in the insurance thread mine changed to two random bike pics, and has now reverted to me without me doing anything, I see Barry Carson has now changed instead to two bike pics?
For the past three years, I have trailed my bike, from Spain to the UK, then ridden to the Begonia Rally. This year, I thought I might drive straight to the rally, before returning to the UK for a week.
I was wondering if we have a policy alredy in place regarding spam content within ones posts?
How do I contact John Morgan, Can't get an outlook acc for some reason. E -Mail address?.
HELP, I am confused, My 1959 600cc Norton Dominator 99 has an Alternator, Rectifier, Magneto and a 6 Volt battery and I have a copy of the unnaproachable Norton instruction/Maintenance Manual, the nearest electrical diagram is the one for (500 S.S
Hi - I've got a single carb conversion (Amal Mk1) for my Mk2 commando and am generally quite happy with it. Saves all the bruised knuckles trying to adjust twin carbs.
Hi All,
a friend of mine who isnt internet savy asked me to get him a +60 piston for his 1950 ES2. I went to one of my favorite vendors & they list:
500cc: single- ES2, Model18
Hi I'm racing in Belgium my 350cc Manx GP and the front brake has always been a tremendous stopper.
Has anyone knowledge of the maker of Norton Toolboxes, I am told they were on sale at Stafford.
