Semi synthetic 20/50 oil
I have bought some Miller's 20/50 semi synthetic engine oil for my commando and alsoDommie99 once run in.
However, talking to someone the other day I was told that the synthetic part would destroy the oil seals. Is this true?
Not as far as I know, I've been using it since I got my '71 Commandoin 2009 I use the Silkolene version.
According to the technical sheet on this oil,the API specification claimed by Miller is SJ. This means that it will have been tested for compatability with a wide range of the elastomers used for seals in engines.
Therefore forget the information given you your friend/aquaintance.
