All Forum Posts
Lightweight seat
Looking for a new Electra seat anyone know if these are still available can not find any advertised mine has arusted out base and the foam is turning to dust thanks Bryon
Rotaries in Devon
Ian Loram is pushing for a maximum show from 961 Commandos at the Devon Norton Day/Festival/Party. What's the chance of Rotaries outnumbering the 961's ? Richard Negus thinks there are less than 250 Rotaries left on the road.
Commando forks
Hello I have a 71 roadster with early domiator forks,I am rebuilding forks (complete bike) it may sound a stupid question ,I am putting forks back together .
100 years for the curly N
Well this year the 100 years since the Curly N was paint on the side of a Norton tank and Now world famous, and to say it was designed by a Female Ethel Norton , James Landown Norton's Daughter , and she helped out with testing her father work b
Oil filter?
I am thinking of installing an oil filter onto my model 19 rigid. Has anybody else put one on?, if so what kit, where did you locate it, and presumably it's in the return line to the tank, but before or after the rocker take off point?
Air filters
Lest I be accused of hijacking Peter's mail on oil filters - has anyone fitted an air filter to a side valve Norton?
Loosening up
Morning All
My Sport is now over the 1300 mile mark and I'm noticing an improvement in the engine and gearbox as the miles mount.
What are others experiences as the miles stack up?
Rear stub axle lengths
Here I have a Norton rigid frame stub axle. I'm not sure why but when I align the rear sprocket with the tombstone gearbox sprocket in a WD frame (Its a Bitsa) I have to shorten the stock spacer on the opposite side of hub to get it to align.
Crankshaft assembly
This morning I began assembling parts for a new motor. I had a crankshaft that appeared to be in good order but I wanted to check it anyway. The journals are stock grind and unscored. the stroke is standard big twin.
Tight or slack?
Hi all, at the risk of starting a riot,could someone tell me whether advance is tight or slack on the handlebar lever,for a manual KF2 on a Dommi.
Thanks,Mel.
