Ignition warning light
My ignition warning light does not come on when the ignition is switched on. I have tried 4 similar bulbs all of which work off the battery but still will not come on.
Bumped into Sean Kynnersleyat Darley Moor at the weekend and got an update on his new role following his departure from Norton.
Can anyone give me some indication of the value of an F1? 3,000 miles. Original untouched.
Hi can anyone help with a picture of a navigator painted black and polycromatic blue . Was the frame painted black
lady's and gentlemen I'm building a Triton of which has a TLS front brake assembly, I was wondering what held the front air vent grill on they look to be welded rivets.
I am about to order new clutch plates, but I see on the Norvil website that I require 5 friction plates.
I've had a problem with my Oxford heated grips failing to switch off. Looking at various forums it appears that the controller is the offending item. The Version 6 and 7 tend to fail and the fix is the version 8. £29 or therabouts.
Ihave had a read through back messages and have the following queries regarding a frame i have, its marked on the front nearsidetank mount 065632 which i think is the mk111 part number, and on the headstock 00144, there is no frame identifying pla
Can any the more technically minded members think of a solution to my speedo problem?
Could anybody tell me the correct camshafts to use in my 1964 norton jubilee ? Thanks Jim
Hi!
i am looking for my 1967 Atlas:
Hi,I am finally getting around to rebuilding my late father's 1959 Model 50 and have loads of questions.
What thread form are the nuts and bolts and does anyone know a good supplier of stainless items?
Hi. could i ask those that know, is there any difference in the ride height/position between the Sport and SF. they look very similar if not the same.
My mate Jeff, Isle of Wight branch, had the brilliant idea over a few pints, to visit every place in England with the word "mouth" in it ie mouth to mouth run.
Hi
Is there nowhere that restoration threads can be put up? As they can be very helpful when doing your own work
cheers
Lee
Hi
does anyone know how many red Dominators where produced and if so how many are still around
cheers
Lee
Hi all
stripped and re-built the clutch twice in as many weeks,pulled in clutch lever to free plates, heavy as f--k on the kick start, really dragging and heavy
I'm just trawling for some feedback on the Classified adverts viewable on this website. I have twice advertised items on the classified list with a view to selling to a NOC member.
hi i have commando frame no 208215 will this be a 1972 frame or is there a chance it could be a 1973 frame thanks for any help david
I have just obtained an original copy of Motor Cycling, March 12, 1959 which carried the first roadtest of the new Norton Jubilee (XOH 147).
Does anyone know if there is a way of refurbing the metal tank badges or do they just have to be replaced? It looks like they were chromed so i suppose they can't be polished.
Tom
Hi
I have just joined the club and wondered where i can get some information on how many Dominator 99 models where done in post office red and how many are still around,
Hi
I am restoring a '52 30 Clubman Inter, and have found that the LHS slider pinch bolt lug has broken. I have been told it can be welded, and have found a suitably skilled welder to take on the job.
Hello All:
I am working on a 1950 Inter project, re-fitting the wheels.
I was wondering if anyone has experience fitting self-aligning bearings into a wheel hub.
58 wide line frame, what is the off set from the hub to the rim please,?Preferably the centre line of the rim to the hub behind the drum & spocket, as I've aquired a hub with nothing, no spokes or rim & I usually use the taverener wheel bu
Greetings ,
Have been trying to find out what the ideal piston clearance should be and what I have found on the net varies from .0005 all the way to .0010 ( Supposedly for racing engines)
Hi All
I have removed the timing cover on my mk2a Commando fitted with Rita Ignition, consequently will need to re time the ignition when replacing said cover. Any tips for setting up would be appreciated. Thanks
Has anybody replaced the tappets and there bushes
Thanks. Jim
