All Forum Posts
Bit disappointed
That I was the only Norton on the Distinguished Gentlemans ride in Sheffield on Sunday..next year get yerselfs sorted please...its for a good cause.
Rocker arm lift ratio?
Hello all,
Could anyone out there tell me what the rocker arm lift ratio is for the late OHV singles made by Norton, not the AMC engined models. No particular reason, just curious.
Regards,
Albert
650SS oil pumps
I am about to refurbish an oil pump as part of my 650SS engine rebuild. I believe I have the correct pump for a non pressure rocker feed engine as it is a three start drive with wider gears. I am interested in the stampings on the pump:
Spanish importation changes
It appears that changes to Spanish Importation Law mean that you cannot import a vehicle into Spain as a resident unless it has a Certificate of Confirmation (COC), if not or if older than 25 years it is necessary to be inspected by "a laboratory"
Concentric carb setup
Hi. i have fitted a 932 concentric carb to my es2 500cc this fits the intake ok size wise just wondered if someone could tell me what the jet sizes for the main/pilot/needle should be. also which slide to use .Baz
Commando import
I have bought a Commando from USA and on the US title it states it is a 1968 this is plainly wrong as the frame no is 138130 and club records confirm it as a 1970 Roadster.
Observation
Just looked at the technical questions and find that the number of Commando conversations are 961smiley
