I have a big 4 1952 with a…
Previously David Cooper wr…
Thanks, Bryon - I'll get the tape measure out.
I had a 2nd look with there being hundreds of KN filters a number might help stamped on the top was B030A4 Part no was R1140 but this could be a dealer no This filter loks and works well Bryon
David, air filters were al…
David, air filters were almost invented for side-valve Nortons ! Apart from the wartime Vokes which was developed by Nortons and Shelley's associated company Talboys, the Mechanical Warfare Experimental Establishment was fitting this stylish number to 16Hs as early as 1936...
Not so handy with pillion equipment though.
Previously richard_payne w…
Hi Richard,
Do you know of anyone in the UK selling the socks for the petrol tank mounted WD air filter. Mine have started to fall apart.
regards, Ian
I have a big 4 1952 with air filter needed for gravel roads which sometimes are used on club runs. I unscrewed the bell mouth which holds the fly screen and clip not mutch of a filter I bought a car rad hose with sharp bends almost 90 deg the same size as the carb mouth and cut out an elbow the correct size for a KN filter could not find fitler no it is2 1/2 in deep and 2 3/4 wide If you point the mouth of the elbow up the filter will just fit close to the oil tank and under the seat 2 jube clips are then used to fasten I tried using thin foam it just bogged the motor down the bike runs well with this set up Bryon
