CafÃ? and Sport suspension
Hi everyone looking at buying a 961
leaning towards the sport but love the look of the cafe'
Tsk, Tsk, a Triumph on the cover of Roadholder? Whatever next ?
I'm sure this will throw 'the old guard' into a frenzy.
Nice picture 'though
James
I have tried to contact the records department using the following email addresstwinrecords@nortonownersclub.orgbut my e mail keeps on coming back saying it cant be delivered.
The original fuel tap on my 1966 650SS, stored in the shed for 23 years, has seized solid and the filter has disintegrated. It is the "pull on/turn and pull for reserve" type.
Sorry if this is repeating things, but has anyone found a good colour match for the late 750 and mk1 850interstates in blue?
French blue has been hinted at.
Has anyone got an original panel that can be matched?
Dear All,i was wandering if some of you have and could share a copy of the tuning sheet I have read the factory prepared for the installation of the 4s cam.I understood they were prepared tuning sheet n. one and n.
Hi there, hope this hasn't been covered before. Found 0.5mm/ 0.020" enfloat on the inlet cam when checking timing chain (can't tell what the figure for exhaust is). I have two questions...1) Is this worth dealing with yet ?
i'm restoring a very early navigator and the conrod small end is badly damaged ,i think it happen due to a broken piston , i have looked for a replacement rod but can't find any , i was thinking about repairing it with a bush and i was wondering i
I know both the 'small' tank and large petrol tank were available on the 1962 650SS.
I have just in the process of fitting a new wiringloom to a bike I purchasedlast year.
I have noticed several regular users have a picture next to their postings on this forum. Am I missing something obvious because I cant work out how to set one up.
Andy
Will my 1959 600cc Dominator 99 run on modern unleaded petrol?,or should I use a petrol additive?, if so what should I use? any help would beappreciated.
Thanks.
Calling wideline dominator owners, i am trying to to rebuild an 88 from a total basket case where many parts are missing. I have a tank at last, a strap which i think is the right one, and a new seat.
just removed what seems like a small drain plug from the outside casing of my engine. Underneath the oil pump. I was expecting to find a spring and ball bearing? But there was nothing there, should there be one?
This is a really silly question - but I'm stumped. The magdyno chaing on my 16h will not maintain its tension, becoming excessively loose in a few miles.
Hi has anyone got any tank badges my navigator in a box is missing them
Is there a source in the UK for an uprated Mk.3 starter motor apart from Emery/Norvil ?
sam
Does anybody know where I can get a gearchange lever to suit a Laydown gearbox. Any help appreciated.
Bill
is any one from the club going to the cork show (ireland) on the 1/2/15 i was going on my bike
Given that I'm going to have to bite the bullet and give my Commando (Mk3) gearbox a FULL overhaul, has anyone any experience of the bearing puller sets (slide hammer type) as sold 'online'?
For those who wanted to continue with this thread, The 99 is still in bits.
Hello there,
Does anyone have any up to date news on Norton Motorcycles UK.?
I am about to fit the scrolled lowpresure rocker spindles in my Dommi head.
My Mercury is smoking when I start it after 3/4 weeks. Is this just wet sumping and if so what can I do to stop this.?
Hi All,
Stuck yet again!!
Self extracting bolt didn't do what it should, Phil kindly advised heating & tapping to remove, but it wont come off, does anybody have any more ideas how to release this please.
Further to Mike Pemberton's article in RH this month about cylinder head work on a single, he mentioned a measurement to take in order to check for correct valve seat depth, namely from the tip of the valve stem to the face of the head, where the
I've been trying to source these for my bike. So far without success - any ideas please?
Hello does anyone own a jubilee deluxe that could give me the correct height for my front mudguard bracket clamps, a measurement from the bottom of the fork leg to the clamp would be good.
Cheers Kelvin.
