Tracing history
Following a conversation with a friend of mine todayI am wondering if it is feasible to try and trace some of the history of my 1936 International engine.
Looking for a full set of correct style handlebar clamps or can anyone advise an alternative other than later yokes?
Recently purchased a late Commando electric start. In large pieces, the gearbox was dismantled in a box. Not sure where this spacer goes. Any ideas?
Cheers Andy
I suspect my Tach is cream crackered, the instrument in question has functioned flawlessly since I bought the bike17 years ago. Whilst on a recent ride the neeedle suddenly started sticking & twitching all over the dial.
Good evening
I bought an es2 of 1939 with matching engine and frame number.
But how i know if it's the right gear box.
Has an es2 the same gears as for example a 16 H or 18?
It's a four speed box with numbers N8001.
Has anyone had any experiences (good or bad) with Classic Insurance companies? I've just used Moneysupermarket and there seems to be a number of companies offering Insurance. I want to pick the right one!
I have a 1956 19s, the frame I believe to be similar to the early Matchless AMC type ,
How do I remove the rear brake lever to inspect the return spring any info would be greatly appreciated.
Thank you.
Hi to you all
having recently bought a 1959jubilee in need of resurrection
i could do with your help!
it is about 50% complete so im looking for a vast amount of parts for it !
mainly frame/cycle parts
I am trying to document Norton engine component weights , so I asking for the following weights of original Norton pieces found in an 750 Atlas, P11, P11A, N15CS, N15CSR, G15mk11.....as they all share these same pieces -
Where do I find the Engine and Frame numbers on a Norton Electra?
in 1964 my brother had a 1959 88 Dommi and I have a photo of me on it down in Brighton ( i am an Oxonian) ,at 16 years old, having ridden down there with no gloves or helmet and my mother on the back in the same guise, confidence oozed from me the
I bought a '61 Dominator 99 a while back, and the previous owner said that it has a 59 head on it.
Hello we suppose to have some rolling photos but I cannot see them rolling much as they been static for well over 4 months now, the same few photo flipped over and over, This is not my Idea of rolling photos, Has the Club run out of Pictures , or
Hello can anyone help with the following problem, I have a selection of chains that I have ordered for different bikes and I was sure I ordered one for my jubilee, one of them is a Izumi 428 121L, is this the correct chain.
am I the only numpty who doesn.t know whata URL is
i have had a look at the two colour tanks painted on the web pictures but could someone let me know if the total underside of the tank is painted the bottom colour.
I would welcome advise on which tyres to put on my electra currently it has front avon ribbed 3.00x 19 and avon block tread3.60 x18 rear manual states the tyres should be 3.00x19 and 3.25x18
Hello,
Can somebody tell me what the correct pivot center distance is for a 1938 model 18.
7/8" and 1-1/16" pivot centers are avaliable but which one is the correct one?
I assume hÃ?ndlebar diameter for that period is 1"
What models and years do they Model 7 engine & gearbox plates interchange? STeve
My Commando suffered wet sumping quite badly. After one week I had to drain the sump to enable easy starting. I came up with a cure which entailed putting a ballofix valve in the oil feed line.
Hello Now The Engine Room Is my bit for the club member to answer there problems with the Bracebridge Built Motorcycles Only, so posting hear please , to the engine room Bracebridge Street motorcycles twins are my speicalty , Yours Anna J
Hi All,
Just trying to see if anyone has any spare Jubilee parts for sale.
Can anyone recommend a supplier of brake linings which have some 'bite' I have previously found modern friction materials lack the braking performance of older asbestos based friction materials
For a 1958 Norton Dominator 99 Wideline Petrol tank, can anyone help describe the thread type and length of the screws that hold the round tank badges and knee pads? The knee pads are two screw type.
Looking to purchase or make the proper tool to remove head and barrel nuts that are buried on under side of head and looks to be the same clearance issue on barrel stud nuts the one in particulare the center head stud nut.
Hello, ive just been stripping my 19s engine and on removing the rocker box i noticed there are hardened caps that sit on the valves inbetween the rocker arm and the valve stem top just wondering if these were fitted to the es2 engine as well.
Are there any norton gatherings or events being arranged during the TT?.
