Rotor nut
Evening All,
I have removed my primary chain case cover and want to get to the backfire device? How do I get the bike in gear so i can undo rotor nut or do i have to put it all back together place in gear then take apart again?
Evening All,
My 99 has non-standard fenders, I've acquired a damaged rear one which has a dent near the front mounting hole. My body man is removing it and repairing other damage.
Evening all,
I have established my anti backfire device is slipping, request advice on how best to set this correctly? All help appreciated.
Phil
Gents, I'm trying to locate a Front girder fork steering column lock nut for my 1936 ES2. I've struck out at all the places I've contacted in the UK.
In 1953 my father, Ron Jerrard, rode a 500 Inter in the Senior Clubman's. The bike's number is 50,831. If anyone knows of it's whereabouts, his son would be grateful to know.
I've just been having a read through this months Roadholder and noticed the 2016 international rally is in Rimini, Italy and would coincide nicely with a rally I do every year in northern France.
Hi does anyone know the thread dia and pitch of the spark plug on the navigator cylinder head.Mine has sheared off andon investigating I think it has been aradited in
Can anyone share me the photo of the original rear number plate holder for 1953 Norton Model 7 and let me know from where to get it?
Also please let me know if anyone has spare for sale.
Hi, I am new to NOC and need a little help please .I am about to own a 1933 mod 20 which will need rewiring does any one have a diagram for this bike ? or some advice thanks Dennis
The oil tank feed housing the filter gauze is damaged. Does anyone know if you can buy replacements?
I have a norton 50 1957 can you supply me with the correct wiring diagram it has a mag /dyno model, also the correct centre stand and part number if possible. It has a single downtube frame and divides into two under the engine.
I am refitting the forks / stanchions / sliders into the yokes, can anyone advise the best way to ensure they are not twisted.
According to the workshop manual the tightening sequence is simple to understand, but not the torque settings. All but two of the nuts and bolts on mine are 5/16" heads with the exception of the two underneath at the front.
The state of my knees and hips due to advancing age has made me decide to convert my Mk IIA to electric start. I assumed it would be a simple case of buying an Alton kit and installing it but it's turning out to be more complicated.
hi all,i have been reading the various comments on recommended oil and circulation with great interest so i would like to put my question in re my 55 model 7.it is very near restored,engine starts up fine,previous owner had a rebore done,the new p
Is there a source for engine clearance specifications for a 1936 ES2? I am fitting a new piston & rings, and need to hone the cylinder to remove a bit of surface rust.
I need a speedo, speedo bracket, speedo cable and horn for my 16H project. Can someone guide me to a place where I can get such items.Comments on experience with Indian made productsare welcomed.
thanks
Can anyone advise what the front of the chainguard fixes to? I have a repro N.O.C. chainguard with two bolt holes at the front but no bracket to attach it to on the bike. Are there any detailed Dominator frame part diagrams available?
Is it possible to fit a Commando cush drive rear wheel in a Dominator? Is it a good idea?
I just happen to have all the parts.
hi , has any one used tapox in a fiberglass tank and does it work. still dont know what to do about the ethnol problem.
If your interested in seeing my Electra undergoing restoration I've create a page for it here... (nothing commercial...)
hi, one of my spark plugs is constantly getting badly oiled up and that cylinder is smoking a bit so removed head today and looking through the exhaust port the exhaust valve is covered in oil, the inlet seems pretty dry.
hi all,any suggestions please if and where i can obtain the flanged rubber pieces behind the tank badges,for a 55 model 7,the badges are round,as for that year.if not,any suggestions? thanks
should my 1959 machine have a hinged seat, like my 1965 T120 had?, thus giving access to the tool box therunder (could this be a new word) he thinks. any help on this Guys?.
Regards Pete.
Hi
Justputting a dynamo on top of the mag on a 19S (what a palaver) should there be any kind of gasket/rubber between the dynamo and the top od the magneto to insulate them from `fretting`?
Stumbled on this film last night, a fantastic trip back in time, there are some Nortons in it too
Laurence
I have a Mercury first registered in 1970 and want to scrap the twin carburettors and set it up with a single 930 concentric. I have a manifold but would like to know if there would have been a thick gasket between the
