All Forum Posts
Norton Nacelle ?
Tsk, Tsk, a Triumph on the cover of Roadholder? Whatever next ?
I'm sure this will throw 'the old guard' into a frenzy.
Nice picture 'though
James
Fuel tap
The original fuel tap on my 1966 650SS, stored in the shed for 23 years, has seized solid and the filter has disintegrated. It is the "pull on/turn and pull for reserve" type.
72-73 Interstate blue
Sorry if this is repeating things, but has anyone found a good colour match for the late 750 and mk1 850interstates in blue?
French blue has been hinted at.
Has anyone got an original panel that can be matched?
1949 ES2 cam endfloat
Hi there, hope this hasn't been covered before. Found 0.5mm/ 0.020" enfloat on the inlet cam when checking timing chain (can't tell what the figure for exhaust is). I have two questions...1) Is this worth dealing with yet ?
Navigator conrod
i'm restoring a very early navigator and the conrod small end is badly damaged ,i think it happen due to a broken piston , i have looked for a replacement rod but can't find any , i was thinking about repairing it with a bush and i was wondering i
Model 7
just removed what seems like a small drain plug from the outside casing of my engine. Underneath the oil pump. I was expecting to find a spring and ball bearing? But there was nothing there, should there be one?
Gearlever
Does anybody know where I can get a gearchange lever to suit a Laydown gearbox. Any help appreciated.
Bill
Cork show
is any one from the club going to the cork show (ireland) on the 1/2/15 i was going on my bike
Valve seat recession
Further to Mike Pemberton's article in RH this month about cylinder head work on a single, he mentioned a measurement to take in order to check for correct valve seat depth, namely from the tip of the valve stem to the face of the head, where the
