CafÃ? and Sport suspension
Hi everyone looking at buying a 961 :)
leaning towards the sport but love the look of the cafe'
just wondering has anyone rode both how did you find the suspension and riding position between the two? pretty flexible being 6'2 and 25
also anyone around my weight 12-13 stone care to comment on the suspension for our weight
Cheers hopefully a 961 owner soon :)
Thanks,
Tom
Hi Tom
If I am converting correctly I am smaller (173 cm) than you with around the same weight frown
I tested both Sport an CR. The CR needed a bit time to get used to. I had the opportunity to ride a CafÃ? Racer for a few hours before I decided to buy it.I really recommend you that you try the CR for a while before deciding to buy one, because with your height it may be less comfortable than for me.
Personally, I like the look and also the riding position of the CR. I did a bit more than 12'000 miles with it within the last 2.5 years.
RegardsRaphael, Switzerland
Hi Raphael,
Thanks for the reply that really helps alot Id probably be really cramped on it then, interesting point you have made :) hopefully test riding a sport next week so fingers crossed i fit comfortable on that one
Thanks again,
Tom
Previously raphael_vonaesch wrote:
Hi Tom
cafe racer left alone for a couple of months now flat battery and from basic norton book supplied with bike have to take seat and tank off to get at battery has any member done this yet the garage i rent doesnt have electricity and can i leave some leads from battery when recharged to jump start or connect to optimate so i dont have all this polava, hope members can help
On my Sport model there is an external charging socket meaning you don't have to remove anything to get at the battery- your Cafe Racer should be the same. Only discovered this after calling Norton when I had the same low battery problem.
Feel under the seaton the left rear side of the bike next to the top attachment of the suspension unit and there is a round cavity inside which is a male two pin DC plug on a short length of cable. You will need to buy the female DC plug that fits the male endto attach to a battery charger - Maplin stock this female DC plug for about a fiver.
I've just changed my battery after two and a half years - no longer holding charge probably because I didn't keep it topped up between regular two or three month lay offs , soif you only use bike sporadically advise you top up battery regularly using this convenient external charging point.
charging poin many thanks James i,ll have a look and let you know
charging point many thanks James i,ll have a look and let you k
nowMany thanks James its there.you,ve saved me a lot of work thanks
