Fitting a chassis
Hello,
We have a 1951 ES2 500 OHV, and weare going to fit our Noxall sidecar to it, at the rear of the frame, at the bottom of the frame there is a hole, and 6 inches above there is another smallerthreaded hole, which hole do we fit the chassie fitting to as we have seen both holes used on different combinations.
regards
Roman
Hi Roman, I am currently doing the same, fitting a Dusting sidecar, to my '51 ES2 and am going to utilise both holes you see by bolting a vertical 2"x 3/8" x 7"long flat bar across both holes, to which I am attaching the flexible knuckle of the chair chassis.
My SOLOMod 18 long roadholder forks, is fitted with sidecar Yokes ( Crown Set ). I would like to purchas a Solo set or possibly exchange my Sidecar Set
Hi Peter,
Is it possible to attach a picture of your fork yokes that youare looking to exchange? Thanks, Richard.
Hello Paul, What a good idea we shall do the same, is there any chance of any pictures, we are at cuckoolanduk@btinternet.com
regards
Roman
