Hi again everyone help needed with my centre stand when I bought the bike it was cable tied out the way because the double U shaped clip was missing I have replaced that and yet it still hangs far to low to use the top spring hanger appears to be in the right position (it is a Triton) and the spring is not stretched any help gratefuly recieved thanks Chris
Hi had the same problem on…
Previously barry_carson wr…
Previously barry_carson wrote:
Hi had the same problem on the triton i had. i couldn't find a spring to fit. so i went down the trampoline spring route a nice chrome one. these are sold different lengths you may be able to get one to fit. Baz
what size did you use and where from thanks Chris
Hi Christopher. my Centre…
Hi Christopher. my Centre stand had a none genuine bracket fitted to it so it wouldn't be same size spring as yours .i had mine off e-bay i thought nothing more durable really. its probably best to go a couple of inches shorter than what you have now. i suppose its trial and error thing really if a standard one wont fit. Baz
My centre stand spring was…
My centre stand spring was also a little bit too long. I got out my gas torch and heated the last flat coil in the stack until cherry red. I next bent this coil to sit alongside the original vertical coil and then dropped the hot end in old engine oil. The result was a double spring at one end which I used for the stand hook. The spring being one coil shorter now had enough tension to hold the stand up.
