Footrest serration angle
If of interest for anyone who has trouble with worn or damaged footrest serration, attached a drawing which may help.
Cheers,
Hans from Chile.
insert-1-jpg
Cheers,
Hans from Chile.
In case you are doing this by machine, another dimension that would help is the angle peak to peak (or valley to valley) which is 22.5 degrees.
OK. The aim to post such a solution was to help anyone that can?t access to made it by machining.
In my case, I own an old lathe, making a special device first to make a serration for my M75 Panther, wich has 20 teeth. For the Norton, I made of the device only the plate, with 16 holes, equal to a 22.5? each.
Attached the device.
img_3598-jpg
Also attached the whole left and right support, ready to be welded, but will wait until completing the restoration, to get a proper angle of the footrests.
img_3600-jpg
