Oil pump service
I've got a couple of Domonatoroil pumps and would like them serviced, is there anyone in the UK who does this at a reasonable cost?
I could do the flat services myself, but as the cost of re-building an engine is considerable I'd like to be sure that they are good.
Thanks Keith
Have a go yourself. If you have several similar pumps then you may be able to mix and match the best parts. For a DIY guide on servicing these chunks...........Go to theRoadholderpages of this site, navigate through the archive toRh 327, February 2015.
Plan B...........ask Dale Middlehurst .........who used to offer a refurbishing service.
Thanks Phil
Perhaps I'll have ago and see how good I can get one.
Keith
This should be interesting??? How will you know what has been done? Will they provide before and after photos and flow tests results? I would hope so as otherwise you might be waving goodbye to £45 plus and not gaining much for it.
