Charging a BOM battery
My bike has a 6v Bom battery inside the old casing ,what sort of charge does it need? . I will probably make a charger out of an old drill charger or similar.
Bom Batteries is a trader based near Doncaster. They attend the major autojumbles. Used to be run by Paul Metcalfe
Any trickle 6 V charger will do the job, plenty to choose from.
Thanks guys,but what i was looking for is the voltage and amperage,I have stacks of electrical gear and will make my own!.I guess about 7.2 to 7.5 v and 1/2 an amp, I'm just not sure what form of battery it is.
BOM stands for Battery Ownership Model. It's a methodology for determining thebest type of battery to optimise lifetime ownership costs. I suspect thet the company BOM sells a variety of battery types. Only they can tell you what you have. I find that a LIDL battery charger does all I want. If you make your own, if your battery is sealed, you want to avoid gassing with its obvious hazards, but I am sure you are well aware of such things.
Hello Well I cannot understand why members like too use 6 Volts anymore Has its getting hard to find 6V bulbs and the like But I do understand there need for originality , or the expense and trouble of going too 12volts ,but the 12 volt system dose have its Advantages Has you have a better lights and you can see better too, some are going too LED lighting witch uses low power So that may be the way forward needs Checking out,more but has for BOM Battery's they seam too be very good , you just have too get the right size for your battery box , but yes check the L.E.D route you may onto a winner , have fun all yours anna j
