Technical parts drawings
Evening all and an early Happy New Year,
I have a 48 ES2 without a front mudguard. Do tech drawings exist for these kind of things and how do I convince someone to provide a copy?
Hi
Do you need to remove the clutch pushrod before using the clutch pulling tool?
Colin Appleyard, of Keighley, who has grown his Colin Appleyard Ltd motorcyle business into a multi-million pound company over 40 years, was awarded an MBE for his services to motorcyle sport.
I am a bit confused over what should be the correct length for the clutch rod for the Laydown box on my recently acquired 1956 Dommie99 as there seem to be conflicting references.
would anyone be able to run a ruler over the spacers that sit either side of the speedo drive on a dommie 88 and post the dimensions, thesearemissing on mybike and i should be able to turn some up. cheers from OZ
Does anyone have any experience with the reproduction Model 7 tanks from India which seem to be all over ebay like a rash at the moment?
Superficially they look pretty good, but their very low price makes me suspicious.
I recently purchased a 1965 650SS and have a query regarding it's original tinware.
When the tank on the Wideline was moved forward, bringing the front of the tank either side of the steering head, what happened at the rear of the tank.
I'm struggling with reconstituting the electrics on my 1957 Dommi 99 and wonder if anyone has experience of changing a dynamo Dommi from 6volts to 12volts.
We are in the process of restoring a 1958 model 88 and wondered if anyone knows if there is anywhere where we can obtain an original looking front mudguard and original looking headlamp holder.
Hi I hopewe all had a very merry Christmas, can anyone tell me if any commando s had fold up front foot pegs thanks Steve
Is there anyone out there who has one of these, who canassist with some photographs, dimensions etc reference gear change linkage, tank plate etc or who doesn't live a major distance from Bristol and would be happy for me to come round and take pi
Does anyone have a photograph or picture of the engine plates for a plunger frame model 7?
I have seen so many different types of engine plate at autojumbles and I want to make sure I get the right type.
Hi
Can anyone suggest a good way of removing the nut which secures the alternator on my N15. At present, when i try to loosen the nut the primary chain goes round. The back wheel and drive chain have already been removed.
m e r r y x m a s
h o w d o I f i x t h i s p l e a s e ?Attachments
Hi All. I'm a relatively new Norton owner and member od the NOC. I was lucky enough to find a Trio of featherbed Nortons that had been stored since the 50's- a 1952 Model 30 International, a 1951 ES2, and a 1950 Daytona Manx.
I'm looking for a 21 tooth engine sprocket for my pre-war inter but am struggling to find one. I understand they come in a number of offsets as well, mine measures up as about 0.125, but I don't know what the various offsets are.
Has anyone come across a method of cleaning the residue of this modern petrol out of a tank.
Have any other members received the current Roadholder magazine twice??? If so it is an awful waste of club funds.
I am currently helping out another NOC member to finalise the restoration of a 1954 dominator. We have encountered a problem with the drive arrangments for the dynamo via a slipping clutch.
Can anyone tell me where I can get a sealed bearing for the high gear pinion on a laydown box? and part no if poss please. I'm trying to keep the oil in the gearbox!
I am not trying to make a political point, but the present Roads Minister, Stephen Hammond, appears to have stood against, and overturned, two pieces of EU legislation that would have had a detrimental effect on many of us.
Hello - I've got my Navigator engine on the bench and have put the gear box in but when going through the gears, I sometimes find a neutral between 3rd and 4th. Is this normal or do you think I have put gear box together wrongly?
Hi.
Does anyone know the cross reference of a 3rd gear pair ( gears ) for a 61 Jubilee?
I amassisting a French Enthusiast who has 3rd gear jumping out.
There is the 3rd Main listed but I also need the 3rd lay.
Hi
The time has come when I cannot put off replacing the original Bowden throttle and air cables on my 1927 16H.
I have recently purchased a 1976 850 Commando, repatriated from the USA, I removed the front wheel to replace the tyre,
and have a few questions about the front wheel spindle:
1) Is there a recommended torque setting?
Has anyone first hand expeirience of running a drouin supercharger on a Norton? i have just bought one off ebay and if i can repair it (needs new bearings and drive belt) i will fit it to my 750 commando cheers nick
I'm in the process of reassembling my '36 inter engine and I've hit a problem trying to fit the head. I need the lap it in with the barrel.
