Hi
Can anyone suggest a good way of removing the nut which secures the alternator on my N15. At present, when i try to loosen the nut the primary chain goes round. The back wheel and drive chain have already been removed.
Thanks for any advice anyone can offer.
HI. You need two old clutc…
Thanks for the reply, Ian.…
Thanks for the reply, Ian. You say you prefer the idea of the clutch tool. Would this still be your favoured approach if you were rebuilding the engine?
A rattle gun will work ,or…
A rattle gun will work ,or i have heard of locking the motor up with thin rope through the plug hole!!. I usually put the bike in top gear , with the front wheel up against a wall and tighten up the clutch springs a bit.I leave the transmission on untill all the nuts are loose inc the cam nut, i have a cutaway timing cover to avoid strain on the timing gears and spindle.I also break the head joint by running the motor with the fixings loose.
Hi. Yes, the clutch tool w…
Hi.
Yes, the clutch tool would be myweapon of choice, Just make sure the handle is substantial enough. The plate that I have also works well enough but there's always the chance of nicking the rods ifthe crank suddenly decides to rotate under its own weight when the pressure is taken off the crank nut. Also, if you've got the clutch tool there's no need to take the engine apart should you need to get the alternator rotor/engine sprocketoff again.
Cheers.
Ian.
Previously wrote: Hi. Yes,…
Hi.
Cheers.
Ian.
Hi Ian
I have taken a photo of the current state of play. I cannot see where the clutch tool attaches to the clutch. I am a novice, as you will have gathered!
Best wishes
John
P.S. I do not seem able to download the photo for some reason. I could email it to you....?
Previously wrote: A rattle…
Dear Robert
Thanks for the guidance. I think I need to go on a motor cycle mechanics course.
Best wishes
John
Put the back wheel and cha…
Put the back wheel and chain back on. Put in in top gear and put the back brake on hard (a glamorous assistant may be required). Then undo the nut. Use a long ring spanner or socket and you may have to wallop the end with a hammer to start it off. Tedious but simple, a bit like me really... Gordon.
Hi. 'Ere we go, this show…
This shows the spacers req…
This shows the spacers required to allow it to slot into the clutch body.
Attachments IMG_0002.JPG- Log in to post comments
Another shot of the tool -…
Another shot of the tool - one of each type of plate, one with the tangs on the outside, one with them on the inside rivetted with pop-rivets. The mounting bolts to the handle take the 'strain'. The extra holes are where a previous 'handle' fitted. It wasn't up to the job and itbent.
Attachments IMG_0004.JPG- Log in to post comments
Finally, this is the tool…
Finally, this is the tool in place, locking the inner and outer drum together so locking the whole primary drive up allowing you to undo the crankshaft nut (remember to undo the one on the other endin the timing case if your planning a complete strip-down) and the clutch body nut.
Hope this makes it clearer.
Cheers.
Ian.
Attachments IMG_0003.JPG- Log in to post comments
Wow your one has even got…
Wow your one has even got a smart grip on it! Makes the one I cobbled up look a bit agricultural. Gordon.
Period item that grip! Cam…
Period item that grip! Came off the old man's Dommi!
Thanks everyone, especiall…
Thanks everyone, especially Ian for the photographs. I have done as you suggested Ian and it worked. Thanks again. John
HI.
You need two old clutch plates - one of each type - rivetted together and then bolted, with two 1/2 inch spacers, to a two foot length of steel bar ( I use a length of 1" x 1/4" steel 'strapping' from a builders' merchants). This slots into the clutch and locks up the primary drive. It's also useful for undoing the cliutch nut. The other way is a piece of thick alloy plate with a slot cut in it to clear the con-rods which fits under the pistons so locking the crank assembly.
I'd go for the 'clutch-tool' myself!
Regards & Christmas good wishes!
Ian.
