21T engine sprocket
I'm looking for a 21 tooth engine sprocket for my pre-war inter but am struggling to find one. I understand they come in a number of offsets as well, mine measures up as about 0.125, but I don't know what the various offsets are.
Can anyone help with what the offsets are? And where I can go looking to buy a new one?
Try contacting George Cohen, he knows a great deal about the older singles. If the drive side main shaft on the OHC models is the same as the SV and OHV models, perhaps a sprocket for the inter can be obtained through RGM, they offer engine sprockets of up to 23 teeth in all of the various offsets.
Thanks for that. I believe they are the same as the OHV and SV models, ill double check before I buy though.
I got a sprocket from RGM but unfortunately the taper up the middle is a completely different size, they have been very helpful and I sent them my old one as a sample. However they don't have any sprockets of the right type. Does anyone know where else I cold to looking for an Inter sprocket?
RGM have said they could have a batch made but it will take several months, seems a bit long winded if someone else is already selling them.
Ken McIntosh lists them.
http://manxnorton.co.nz/catalogue/catalogue.jsp?m_id=2&c_id=18
I've seen that. Was just wondering if there was in the UK first, if not I'll have to contact him for one.
andy....i,ve just had a 21 tooth sprocket for my dollshead gearbox made by john hemmings.you can only buy 19th for early gearbox,s
so i sent my sprocket to him and he welded on a blank then re,cut the teeth,you can get his details from in the old bike mart.
I once resorted to turning all of the old teeth off the existing sprocket and welding a 21 tooth sprocket blank, (with the hole bored out accordingly of course!)into place. I got the sprocket plate from a bearing stockists and was told the sprocket plate is heat treatable to harden the sprocket teeth. It worked nicely.
I can't find a 21T sprocket anywhere at the moment so I may have to turn the teeth off and use a blank as you suggested. Stu Rogers can supply a 22T sprocket so another option is to fit one of these and drop a tooth on the gearbox sprocket to try and even up the gear ratios.
