I'm struggling with reconstituting the electrics on my 1957 Dommi 99 and wonder if anyone has experience of changing a dynamo Dommi from 6volts to 12volts. The regulator and battery would need changing, presumably, but the advantages would be great. Help!
Tom, there is a recent-ish…
Essentially, you need a 12…
Essentially, you need a 12v armature and 12v field coil and an electronic voltage regulator. Then it's just battery and bulbs. I reckon it's worthwhile having done it. Rural roads after dark in the rain now hold rather fewer terrors. As suggested, take a look at the discussion under electrical. Gordon.
Tom,
there is a recent-ish discussion along these lines in the Electrical section.
As with a lot of things the conclusion on whether it is worthwhile is a matter of opinion.
Iain.
