All Forum Posts
Stop the rubbish parts
hello well as you well know now I have the web-master against me now ,Is there no democratic in this club. I am single handedly trying to stop the rubbish parts from being sold .
Dominator dynamo drive
Hi All,I need a dynamo type engine in order to register a 1957 Dominator 99, which I bought as a derelict Triton 20 years ago, so I am building up a 1957 99 motor from what bits I have lying about, however I haven't done a dynamo one before
Clutch back plate
hello in answer to locked out thread! the back plate is the original . but the spider was also out of round at both ends . and the metal is not that hard ether so I am not that impressed with it . I will look for something more original
Armours exhausts
Hello i have just had a fit of my new front pipes and silencers on my jubilee, i seem to have a problem with a alignment issue on the left hand side pipe, when fitted the front pipe is only about 10mm, has anyone else had this problem with new pip
New MoT rules
My 99 is registered as a 1960, it was however Manufactured in 1959 as confirmed by the club historian. I wonder if the DVLC will see it the same way as i do.
change password
Hi
on login any space characters are interpreted as underscore character. this is not the case on the password change page, which made changing my password a bit of a head scratcher for a while
charles wright
Thank you!
I have been missing the web site for the first part of the week. Thank you Chris Grimmett and whoever else got things up and running again. I did try to email you Chris, but the mail bounced, so I suspect the server was down.
Colin.
Hub chrome rim
Hello can anyone help with where i can find the chrome ring that is fitted to the jubilee hubs hopefullt nes ones, i think they are called the embellishing ring. I would have my old one chromed but its a hassle as i will have to send it away.
Amal settings
I've got a single Mk1 Carb on my 73 750 with a 250 main, 106 Pilot, No 3 slide and needle as low down as it will go(Top Groove) I'm running BP7ES plugs and it's running rich and fouling after 50-60 miles.
Jubilee tyres
Hello what size tyres should be fitted on my jubilee deluxe as standard, I have a 3.25 on the front but it had a 3.50 on the rear. Both are 18".
Cheers kelvin
