Speedo drive spacers
would anyone be able to run a ruler over the spacers that sit either side of the speedo drive on a dommie 88 and post the dimensions, thesearemissing on mybike and i should be able to turn some up. cheers from OZ
I'm currently working on an Atlas which has problems in this area, i will be taking measurements from my 99 to correct the problems, and may be able to help you.
Bruce
Don't take these measurements as gospel as they are from my 1957/8 Inter. I don't know about the Dommie they may differ. Others may not agree. The large outer one is exactly 1" in length. The inner one was missing when I rebuilt it, requires a very thin one so I just put an old spark splug washer in, that way it compressed and fitted quite snugly putting no pressure on the case and holding it secure. I have had no problems.
Hope this helps.
Happy New Year to Oz. Be there soon in Feb/Mar (ADL and BNE) Can't wait to get away from this wet weather here in the UK.
Ian
Bruce
Hope this helps.
Ian
Thanks Ian, i'll try that and see how it fits up, there looks like there should be another larger spacer between the drive and the bearing do you have that on the inter?.PS it is going to be 41 C here in adelaide this week so wet weather is not a problem
cheers bruce
