All Forum Posts
ES2 valves
I wonder if anyone can help with a bit of a technical question.
I have recently purchased two new valves for my 1955 ES2, part number V37 on the owners club site and also on RGM motors site.
1971 Fastback
Have imported bike into UK and need to MOT and Register same,
Not sure if indicators were fitted to the machine! Any idea when they
became legal requirement?
Registration plate
Hello everyone, I am posting this message to find out how my father would go about sourcing a registration plate for his 1953 Norton Model 7, this has matching engine and frame numbers, but no log book or old tax discs.
Commando centre stand
I have a 1972 Interstate and when i got it some 25 years ago it had not got a center stand, that wasn't any trouble back in the day when i could bend down to do basic servicingbut the knees are not what they were so i got myself a lift hence i nee
Long Roadholders
I'm going to strip the long roadholders on my ES2 in the not to distant future. I suspect I may want to fit new bushes and will certainly fit new oil seals. Are these parts interchangeable between the long and short roadholders?
Final drive chain tension
Adjusting the rear drive chain and noticed when unloaded tension is set to 1 1/2" the bottom of the top chain run is just level with the chain guard lower edge rear of the front mounting bracket. Was this designed in or coincidence?
Fuel consumption
I have a MK2a Commando with a single Mikuni VM34 Carb. I am getting 45mpg riding it like a nun, is this right? I also own a Yamaha XJR1300, 4 carbs, bags of power and i ride it like i stole it, i get 50mpg.
ES2 main bearings
I have trawled through an number of messages on main bearings on this site.
Most seem to be advocating one type or another, and mostly aimed at twins. However none help me so hopefully someone else can.
ES2 1956
My Amal monobloc carb is knackered and I have been advised to replace it with a Concentric model. Has anyone else any experience of this and would you recommend?
