Distributor thrust washer
The 61/62 parts list includes under DISTRIBUTOR DRIVE PARTS
20938 Collar for sprocket
21097 Thrust washer for sprocket
My parts bin included an old 2p piece with a hole in it the size of the distributor spindle, I think that is my 21097 equivalent - does anybody know what it should be like?
My sprocket doesn't seem to need a 'collar' - anyone know what they are? at 1s 4d they can't be too complicated!
Steve, I'm in middle of 62 model rebuild. Checked dist and sprocket 'bags' and to my horror the 21097 thrust washer for sprocket is missing! Can't remember removing one during dismantling though...burt I did find a washer at some stage and wonder where it came from....put it somewhere 'safe' and now can't find the damn thing.
I'll keep looking and post details if its 'the' one.
JMB
I think the collar is actually quite important. My dommi, with an 18D2 distributor, had lost the collar too at some point before I bought it. I remember there being quite a bit of movement in the distributor shaft, in that if you held the distributor vertically, you could move the shaft up and down by about a quarter of an inch - as I say, it was a while ago so forgive any unintentional exageration. Anyway, to my thinking the collar - which is perhaps better described as a spacer - prevents this movement and maintains the correct alignment between the distributor sprocket and the intermediate sprocket. Conceivably, without it if you were unlucky enough to lose your distributor cap whilst riding this alignment could be lost, causing some significant damage I would imagine. Of course, I stand to be corrected, but I was sufficiently concerned to have one made up.
I have had an 18d2 explode when the advance/retard escaped,also the cap can get smashed by the rotor arm, All good fun.
If you don't fit the thrust washer the chances are that the ad/ret mechanism will hit the points back plate wrecking the whole unit - I speak from experience - I discarded the seemingly home made copper washer on mine and everything seemed fine until the distributor self destructed many miles later. It's always worth checking the clearanceas these bits seem to be getting rare and expensive these days.
Regards.
Ian.
I think my thrust washer is not correct for a 1961 99 because it is dated 1971 (see pic), so it must be from one of the early, distributor Commandos. The hole is 1/2" and it is about 70 thou thick - a feeler gauge suggest that another 30 thou would remove pretty much all of the end float. Anything else out there with a bronze thrust washer on a 1/2" shaft? Rocker spindle on an Ivory Calthorpe?
thrust_washer-jpg
Previously steve_marshall wrote:
Solved the problem - one of these with 25 thou filed off/lapped - sorted!....... + £6.75 on PayPal
I just found this thread today when searching another question about the 18D2 distributor. For anyone who is interested I took my distributor off the bike today and found that the thrust washer is 1" O.D., .5" I. D. and .040 thick. The collar/spacer is .75" O.D. .5" I.D. and .45" in height.
18d2-washer-collar-jpg
After checking the end float on my 18D2 distributor, I thought I would change the advance/retard springs as I had a spare set in the workshop. I had to drift rhe shaft out of the drive sprocket and a nylon washer about20mm od14mmid and4mm thick, fell out of the housing onto the bench. The center hole of the washer is champhered on one side. Does anyone know whethr this champhered face goes towards the sprocket or away from if?
I can find pictures of it on the internet but no fitting instructions.
Charles, are you sure that isn't the oil seal? If it is, just take it to your local bearing supplier, they should be able to match it up for you.
Hi.
The 'flat' side of the nylon spacer goes against the oil seal, the chamfer sitsunderthe base of the A/R unit.
Regards,
Ian.
Previously ian_allen wrote:
Hi.
Regards,
Ian.
Many thanks for that helpful information.
Charles
