All Forum Posts
Ist gefunden!
Just like to say thanks to Roland, Mark and Christine (British Only, Pettenbach) and the good people of Austria in helping to and returning my passport and documents, which I lost somewhere between Laussa and Passau enroute from the Austrian rally
Atlas timing chain
Can one of you clever people out there tell me the width, pitch and number of links there should be on an Atlas timing chain?
Did the same chain fit any of the earlier Dominators?
Thanks.
1951 ES2 rims
I'm after some new rims and spokes for my '51 ES2. Does anyone know if they should be lined or are they plain chrome? Are they 19" WM2 front and back? And finally does anyone know a source for these?
Andy
Oil consumption
I am a proud owner of Commando 961 since 11. 2012. With only 1700 miles on the clock the engine is suffering with high oil consumption.(oil used: MOTUL 3000 20w50, API SG, meeting JASO T 903).
Overload backfire device
Hi, I have had trouble for a long time with starting, when I push the button it makes a horrid grinding noise and I have to repeatedly push the button till it catches, I have just taken off the outer case to see what's going on, the noise is the b
961 Domiracer
Well in 2010 when our branch did the tour of the Norton workshops at donington park there at the back was a prototype domiracer on the bench .at the time no one took any notice of it .
Spitting back
Hi folks, iv got my 1950 es2 started. but it is spitting back badlythrough carb on kickstart and running, good spark from magneto,the bike had stood for 27 years, iv cleaned the carb etc any ideas thanks maurice
Salt water damage
Any member lucky enough to attend the National Rally and take the boat trip to the Farne Islands would do well to check over their riding gear. The salt water has started to corrode my press studs and zips.
Paint colour
I have a 1974850 mk1, currently painted black ,rubbing down the petrol tank, for a re paint, I found under the black paint its blue, could this be its colour when newif so does any one know the name of this blue?.
Clutch
Hi I am just putting my clutch together The layshafrt and Clutch centre turn until I put on the diaphram and circlip. Then nothing moves. I have not assembled the Gear box but just have the Layshaft fitted.
