58 wide line frame, what is the off set from the hub to the rim please,?Preferably the centre line of the rim to the hub behind the drum & spocket, as I've aquired a hub with nothing, no spokes or rim & I usually use the taverener wheel building jig as building wheels bare like this is alien to me. I do wish people wouldn't strip the wheels until they're ready to be done
I ask the measurements from the centre line because I'm using a 2.5 rim instead of a 2 x 18
Paul, Slimline rear wheels…
Thank you for the informat…
Thank you for the information it will get me going in the right direction, front wheel not a problem I borrowed the wheel out of my Navigator to copy.
The rear wheel on the navigator is entirely different
Paul, Slimline rear wheels are built dead centre, ie No offset. I can't imagine that widelines would be any different unless someone would care to comment.
There is an offset at the front wheel however.
We usually quote WM 1, 2 or 3 in rim widths but makes no difference where there is no offset.
For offset details, check with the RGM website under Technical Tips.
