Dommy rods
The 99 is in good order generally but the big ends were worn when i last worked on it. It runs without any knocks but i don't thrash it.
I intend to strip the 88SS engine this winter. Mostly to find out why compression is low on one side only.But: it has been sleeved and I don't want to re-bore (should sleeves be over bored anyway?).
I shall be setting the ignition timing on my 1957 Domi 99 soon and was wondering if anybodywould recommendusing a different setting to that given in the manual (32deg BTDC).
Thanks as always,
Thanks for all your suggestions, I have now solved the fork gap problem
Hi all, I just bought a new seat for an ES2 but I thing this one is for 1956 on. And the ES2 I'm working on is from 1955. As it seems to be the same frame, it would be fine to have some pics about a 56 model to seehow to fit it.
I have a pair of roadholders and want to change the seals,the problem is that the seal holders seems to be screwed down into the forks,when I look down into where the seals are there is something which I assume is a seal holder,it has two holes on
Hi, Can anyone out there advise if an ES2 wideline petrol tank has any indents or cutouts to clear the rocker box? If it does a photo would be appreciated. Regards Colin
im thinking to sell my norton dominator 77 1957with matching numbers in very nice restored condition but have no idea what price i should asked can any body help with advice
I am currently restoring a 1968 650ss and unfortunately for some reason, the rear mudguard has been cut away at the bottom area next to the gearbox thereforeI am trying to source a replacement.
I seem to have an oil leak from the front of my 1971/ 750 and have read so much about head gaskets am a tad confused. I would probably go for a quality copper one myself is that the way to go?
i have just had a look at six norton twin wheels and though some have been rebuilt two look original ie rusty and withold spokes [front butted] hardly any match! is there a factory way of spoking?
Has anybody got any ideas about fitting an alternative sidestand to Commandos? - I have a MkIIA and I'd like to be able to hook the sidestand with my left foot such that I could extend it prior to dismounting.
I'm fitting a Reynolds steering damper and have all the parts, or so I thought.
Does anyone know, what is the purpose of the paper washer between the bushes and can a substitute be fitted.
Pete
I was just testing the resistance of my alternator when I spotted that the wires are blue, brown and green and yellow, you dont have to be Sherlock Holmes to realise that its been rewired!
My 1957 dominator 99 has recently started to wet sump.
On starting up only the left hand pipe smokes but clears after a few minutes and will be fine for the rest of the day.
My 1969 commando had a broken barrel base,Common fault in the day,so i bought a second hand one i thought was good.A standard bore is 73mm this one is 73.52.or 73.1/2 My question is what size over is this,and could i rebore it.its looking good sli
Hi
Could anybody tell me where I might get new chromed pushrod tubes for a '54 ES2. Any help greatly appreciated.
Bill
Hi all,I attended the Barber Motorsports Vintage bike event recently in the USA. It was my first time there & had a ball.
Anybody local to the Yorkshire/Leeds area who would like to get together for evening/weekend rides.
I just got my "new" 650SS home. According to the History section they where always silver. But my bike has a green tank with a piece gold striped black. Oil tank and battery cover is gold striped. The seat have a hump.
I have a problem with my Domi clutch running out of true and am looking for some advice.
The bike is a 1954 model 88 but is fitted with an AMC clutch. The bike has just been rebuilt but I have an issue with the clutch.
Back in the 70s I had a 1969 commando and out of all the now classics i have owned (still have some) this bike stould out.So i am resoring one now.Its emportant the bike handels like the one i owned back then.So can someone tell me what size rims
I will be putting the engine back in this weekend after a full rebuild and I'm not sure which way round to install the rear engine mounting bolts, or if it makes any difference?
I love my new cafe racer but that side stand is rubbish to locate and put down anyone fitted a different one?i had a Tiger 800 before the Norton and the sidestand was alloy looked great and was easy to put down safely wonder if i can fit one of th
Albion Tours Mallorca, More Club 59 than Club 18-30
I have a norton frame with a T 110 engine fitted does anyone know what bike it is off the frame no is 103740 believed to be a 650 norton 1962 ?
Some slimlinepetrol tanks have their filler caps left of centre and others on the right hand side. I have examples of both.
