Hi,I am finally getting around to rebuilding my late father's 1959 Model 50 and have loads of questions.
What thread form are the nuts and bolts and does anyone know a good supplier of stainless items?
Has anyone fitted an air filter to a featherbed model 50, if so how?
Does anyone know of someone who can refurbish the oil pump?
Are there any particular pitfalls to watch out for?
thanks in advance. Jak
Hi Jak (No pun intended) M…
Hi Jak, There was no air f…
Hi Jak,
There was no air filter as standard, Norton listed one as an option, but I have never seen one, and doubt if anyone else has.
I fitted an Amal 'cake tin' type filter to mine, but I had to heavily modify the oil tank to get it to fit in. ( see pic)
I use Molnars Stainless parts, they are not the cheapest but are always just right.
Re. the oil pump, I think Norvil and RGM will do them, but it is not difficult, all you need is a surface plate (or at a pinch, a piece of heavy PLATE (not sheet) glass ). Mark up and dismantle the pump and lay the pump body face which mates up with the drive side on your surface plate on some oiled 600 grade wet and dry paper (rough side up!), keeping it flat and squareremove a very small amount of metal, then clean and re-assemble with just the gears from that side in (the feed gears are narrower than the scavenge, don't mix them up). Repeat this until you feel just the tiniest amount of drag, the side float is now gone, now do the same with the other side. Fully reassemble the pump, which must be free to turn dry, if it tightens a little, face off the end plates the same way, but otherwise leave them alone. The pump bodies for the singles are die-cast, so do not go at it like a mad thing, be patient and you will have a good pump with minimal leak-back.
If you don't fancy doing this, as I said I believe Norvil etc will do them.
Good luck, they are great bikes,
Cheers,
Niall
Attachments littlenorton001-jpg- Log in to post comments
Hi, Thanks for the replies…
Thanks for the replies. The bike belonged to my dad andI have owned it now for a few years. I used it to commute in the snow a couple of years ago as it was much better for this than the other bikes I had. Being lower, lighter and doing everything more gently. Unfortunately this high lighted the fact that whoever had restored it in the past had used paint on the frame which has just dropped off. So I am stripping it to get it stove enamelled, but intend to give the engine a quick overhaul and cure the wet sumping. Hopefully back on the road by Xmas.
Cheers Jak
Good luck, jack. I'm a bi…
Good luck, jack. I'm a big believer in powder coating but I know that's not for everyone.
My model 50 doesn't wet sump but my 500cc version does. It will help to slow down wet sumping if you leave the engine on compression and then if you can get a decent ride in once a month that might suffice. On the other hand, if you plan on laying the bike up over the winter just allow the sump to fill but put a drip tray under it.
Hope you found some stainless fasteners and don't forget that stainless rims and spokes are not a bad idea either.
Have a go at refurbing the…
Have a go at refurbing the oil pump yourself!
It is very easy to dismantle, and if you get a piece of glass and some grinding paste, you can give your pump a new lease of life for next to no money at all!
Most of your fasteners will be Cycle thread (26 TPI) except for the engine casings screwing into Alloy. They are the more course Whitworth thread. (BSW)
If you are not going to auto jumbles, you can buy stainless fasteners online. D Middleton and Andy Molnar have lists of Norton fasteners inc other parts, inc spindles etc.There are others too.
I don't think an air filter was fitted as standard and I don't have one on my own model 50 but I do have an experimental Amal thin air filter I keep trying to find. Will report on it when I do eventually find it.
Lots of people can service your oil pump, inc RGM in Cumbria.
Can't think of any pit falls apart from use Ethanol proof parts in your fuel system if you are not going to run on BP Ultimate. (Not E0 in South West England)
