I've had a problem with my Oxford heated grips failing to switch off. Looking at various forums it appears that the controller is the offending item. The Version 6 and 7 tend to fail and the fix is the version 8. £29 or therabouts. When you take the back off the V7 controller there is a diode that fails and relacement is simple, but when the diode fails it burns a bit of the printed circuit board away. Bridge that and you are back in business. Photo to follow.
