hi norton owners!
i just joined the norton owners club, because 4 days ago I was lucky enough to buy a norton international 30(m?) from 1936 in pieces. I do have a little experience at working on engines, and I enjoy the build up/maintenance part as much as the riding part!
nonetheless, this is a new experience for me and I would be super happy to profit of your knowledge guys!!
so don't get it wrong if I ask stupid questions.... starting now:
I'm missing (next to 100 other parts) the carburetor. I'd like to build this engine up to Manx specifications, so I guess the Amal TT is the right choice? is there a technical description of the very model from Amal that I'm looking for? I searched the web for hours....
thanks so much!
ps: if you're interested, check out my Lambretta project, the engine has 37bhp and runs 95mph
image-jpg
Hi Marian, welcome to the…
Previously dave_graham1 wr…
Previously dave_graham1 wrote:
Hi Marian, welcome to the club, that looks like a great project
You can buy a new TT carb from Amal for £390.00
I don't know that much about 1936 Inters, but looking at your picture, your gearbox is late 1940's and the forks are probably WD16H. So I don't know if you're just getting the bike working as it is or trying to get it original? These will all work fine in the bike otherwise.
hi Dave, "10TT9" is exactly what I was searching for, thank you so much!I'm impressed that you instantly identified the fork and gearbox as non-inter 30 parts.. i'm not very concerned about restoring this bike back to stock condition, I just love everything about the looks and sounds of a pre-war TT style race bike. my girlfriend is originally from the Isle of Man, and I want to make her proud
we live in New York, so even if the bike ends up being stupidly loud, I'll figure out a way to register it and make it street legal.are there any disadvantages in using the pictured gearbox and fork?
I'm rebuilding a 57 inter…
I'm rebuilding a 57 inter so cannot advise on the chassis side but for the engine have a look at Paul Normans website, racingvincent.co.uk . Lots of info on rebuilding the engine and if you select the online catalogue lots of difficult to find engine parts. He also does chassis parts for earlier Inters...
Good luck
Mark
Hi Marian Dave is right in…
Hi Marian
Dave is right in saying that the forks are not Inter. The International forks had the brake anchor on the right, also as you look at them âhead onâ they are parallel, all the other models where splayed (wider at the bottom than the top). If, as you say, you arenât worried about original spec to much then these forks will be fine. My Inter has 1939 ES2 forks on it...
The same goes for the gearbox, itâs a post war one but should fit and work just fine in your bike, depending on what model it come from you might find it offers a better spread of gear ratios for use on the road. Itâll be worth doing a dry assembly and checking that all the sprockets line up though, I have read somewhere about different length shafts in the gearboxâs, canât remember where I read it now so please donât quote me one it!
Other than that you look to have a lot of the good bits, do you have a petrol tank? The engine doesnât look to be a manx type one to me, the differences between the manx spec engine and the standard Inter could be another thread all on its own! That doesnât mean you canât put it together with some manx parts in it, and build the bike to look like a racer (I did with mine).
If you are going to build the engine yourself, buy this book. It has loads of information in it, most of which is taken from other sources, but itâs all in one place and will be the best £29 you could spend!
Ian Bennett makes some fantastic parts for the engine, you will probably be able to find them cheaper elsewhere but I have his needle roller big end, cams, camshaft and loads of other bits fitted in my engine, I wouldnât go anywhere else if I was building another one, the quality is second to none in my opinion.
Finally another vote for Paul Norman, his parts a very good quality and he has a good range which he is always expanding on.
Good luck and keep us posted
Andy
small-jpg
Previously andy_marks wrot…
Previously andy_marks wrote:
Hi Marian
Andy
thank you so much Andy and Mark.
your links and suggestions are super helpful. I ordered the book about the engine, and I'll keep you posted about the progress.
i don't have a petrol tank, the one that belonged to the bike did have a signature from a racing driver on it, with names of races and dates (Daytona 1937 and so on), so he wanted to keep this one for his collection. in a perfect world I'd like to buy an old tank, so I'll keep my eyes open.
have a good one, marian
If you intend to ride the…
If you intend to ride the bike on the street the TT carb might not be a good choice. There is no idle circuit in it. As such you have to keep bleeping the throttle when at a stop. Maybe one of the larger GP carbs would be a better choice.
Good luck with the rebuild.
Previously michael_sulliva…
Good luck with the rebuild. Its possible to put a couple of solder blobs on the bottom of the slide to give a sort of tickover.
Previously robert_tuck wro…
that's good advice, thanks guys!
i just had time for a very…
i just had time for a very brief inspection of some parts. in your experience, can i bring these parts to a engine maintenance shop? i can't weld myself..
the fins on barrel and head shouldn't be a big problem to fix, but the crack in the seat of the bearing looks bad, no?
ohc-1-jpg
Hi Marian Have a look in G…
Hi Marian
Have a look in George Cohen's Website - http://www.norton.uk.com
There are lots of interesting things concerning your engine, especially the repair of the cambox.
Derek Ambler
Ouch. If I were you, I'd…
Ouch. If I were you, I'd be getting in touch with Stu Rogers - see this thread :-
http://www.nortonownersclub.org/noc-chat/technical1-singles-forum/632408248
My experience of camshaft Nortons is generally limited to listening to tales of woe, beer glass in hand....but your photos make me rather glad that I run a 1930s side-valve...
Hi Marian Itâs quite comm…
Hi Marian
Itâs quite common to see broken fins, they can be built up with weld and dressed down, then clean it up and youâll never know it was a repair.
The cam box tunnels are also often broken. I repaired mine with the method described on George Cohenâs website. The crack in the bearing housing is more problematic, if you find a good welder it could be welded up and then machined back. I would be more tempted to get a new end cover from Ian Bennet.
Andy
hi, today i tried emailing…
hi,
today i tried emailing and calling stu rogers, but the emails bounced back and the phone line is engaged. did he maybe move, or stop even stopped working? i'd be more relaxed to give my parts to a norton specialist than a random NYC machine shop.
thanks guys, have a good evening!
Stu Rogers openly admits h…
Stu Rogers openly admits he doesn't really do emails. Once you get through to him on the phone you'll realise why he is so often engaged, he can talk for England! He's probably the best person to talk to about yourInter though so keep trying, he'll be very helpful!
Also, I run my 1936 Inter on a TT carb and it's fine, the lack of a tickover is a minor problem IMO.
Back in the day, the trick to make a GP type carb streetable was to drill a #40 hole at the back of the throttle slide just above the bottom where it fits into the carb body. This was something that BSA Gold Star owners in the U.S. did to make the bike a bit more civilised. I never heard of it being tried on a TT carb though. I suppose running a large monobloc could be done or even a standard carb for the street and a TT for track days use.
..so i found and bought a…
..so i found and bought a 10tt9 carburettor! it looks good and pretty complete.
but the diameter of the inlet on the cylinder head(~33mm)is about 4mm wider than the back opening of this carb (~29mm).
are there different versions of the 10TT9?
also i got a hold of Stu Rogers, he sounds like the most helpful person imaginable. and yes, he doesn't believe in emails, so i took a photo for him, of everything i have. you might like it, so i share it with you!
have a good day!
Hi Marian Martin Bratby is…
Hi Marian
Martin Bratby is the guy to talk to about your carb. Another guy who doesn't do emails - 01543 572583. He'll be able to advise you on the sizing and can overhaul the carb for you if its needed (I'd reccomend it, it's one less unknown when you start trying to set the bike up and put it on the road)
