Replacing Commando fork seals
This is a job I can no longer avoid.
I have been quoted £70 by a local motorcycle dealership.
Please could I ask exactly what needs replacing so I can furnish them with the correct parts. I already have the fork seals and will be able to tell them what grade of oil to use but are there any other itens such as washers that should be replaced?
Here is the link address for Mick Hemmings fork stripdown.
Andover Norton have good parts diagrams on their website.
There are paper washers by the seals and seal washers for the bottom of the forks. Then it depends on the state of the forks, if the chrome on the Stanchion's is damaged then the seals will get damaged, if the Stanchions require replacement then its worth changing the bushes.
It depends on the condition found on strip down, Good luck
Thank you for that Christopher.
I will have a good read of the Hemmings article and might do it myself.
The bike is in very good servicable condition so hopefully it will be a straight forward replacement job.
I seem to have spanners that fit everything apart from a Norton fork tube top bolt Can anybody tell what size spanner I need for it?
Thanks in advance.
I notice Mick Hemmings is stripping and re-building Roadholder forks - is the procedure for Commando forks exactly the same?
I found 3/4" Whit fits. I did mine earlier this year. Undoing the seal and bush retaining rings needed some heat and Plus Gas otherwise thethe job was fairly straighforward. (the first time for me too) You should consider replacing the bushes too while you have them apart. I haven't read the Mick Hemmings procedure but I believe the Commando forks are the same as Roadholders.
fork-seal-bush-and-ret-ring-jpg
Yes it is the only difference as far as stripping is thread sizes. I found a 33mm impact socket from Halfords fits the top bolts if you can not get a 3/4 Whit.
PS Micks artical tells you all you need to know.
Just done this myself. I had read you could do it in 60mins. What a plonker that guy was.First time, took me about 4-5 hours. Changed top fork seal and bottom washer so spent a bit of time cleaning out bottom of fork alloys where someone had gunked in previous washer.
Im sure it would take less time if I were to do it again as with most things.Have a crack at it. Good Weekend job to do!
