All Forum Posts
Metal adhesive/repair kit
Has anyone any experience of "Delta Quick Steel Repair and Retain" adhesive/repair gel? It's sold by Frost Restoration. I'm interested in it's Adhesive qualities as I cannot weld or braze. Many thanks for any input. George
Damper/stop plate set up
Just reassembled the front forks on my Dommie rebuild, The stop/damper plate under the headstock looks like it needs spacer under it where it bolts to the frame but I can't find a spacer in my box of bits from when I took the bike apart.
ES2 Valve Lifter
Is it possible to get a square type O ring for the valve lifter on a 1954 ES2 ? The groove is quite wide. I have tried 2 o rings side by side but they just break apart and a lot of oil leaks out.
Dominator tank refurb
I would like to have my 88 Dominator tank repainted and was wondering if anyone can recommend a company or person that does this. I have had one quote of £500 which seems excessive to me but maybe that is the norm. Any advice welcome.
Ethanol
There is no Ethanol free petrol without a fair ride near where I live. What Ethanol protection do others use in their fuel?
I have been looking at Millers EPS Ethanol Protection.
What will they put in fuel next? Roger
Indicators on a 99
I have working indicators on the 99 but to fit them I drilled holes in the old headlamp. Now fitting a new shell I would like to mount them on the HL bolts (cycle thread?) Are the parts availiable? Anyone done this?.
16H frame threads
Hi, I have a 1943 16H which arrived in boxes! I'm dry building it and can't seem to find the thread that's used in the frame to secure things like the seat, speedo bracket etc. Is the thread standard through the frame irrespective of the size.
pushrod tube washers
I ordered a decoke gasket set from the NOC shop but when I attempted to refit the cylinder head/rocker box assembly the rocker box would not drop low enough to engage the retaining nuts owing to the thickness of the lower pushrod tube washers.
Suffolk
Hi Everyone, This year's camping rally is in Suffolk, and is being hosted by the Essex branch, because we have no Suffolk branch.
