All Forum Posts
Magneto dismantle
Hi all - major problem. The alloy casing of the Lucas Magdyno has always had a crack at 2.0 o'clock when viewed from the timing side. As the bike is now stripped down I thought I'd fit a new casing (which I already had).
Dominator 88
Does anyone have any experience of fitting a 26mm Concentric to a single carb Dominator 88 and if so could you advise on what jetting you used please
Broken Magdyno housing
speedometer
Hi, i am thinking of using a repro Speedo on my es2 to replace my chronometric one because the new bezel i fitted wont stay tight i have loctited it but it still comes loose the old one was cross threaded the thread was damaged so i put it down to
Norton P11
I'm looking for any information regarding the Norton P11,
Particularly values. I have a certain interest in a 1967 road going model with matching numbers.
Dealer history.
Hi, just putting finishing touches to my 1964 Norton Atlas which was origionally supplied to R.H.King, 52 - 56 Cauldwell Street, Bedford. on 6th. May 1964. Trying to locate the dealer decal or mud gaurd plate.
Rocker box stud
Hi Guys, I've found why there is a constant oil mist round the top of the engine. One of the rocker box retaining studs has shed its threads in the alloy head (55 ES2). It's the centre front one at the rear of the exhaust valve.
ES2 Rocker arm woes
My 1951 ES2 is currently in pieces as I sort our various "issues"
My mechanic friend has advised me that I need new valves and valve seats on the exhaust side and fortunately the NOC has stock
