All Forum Posts
VIN plate rivets
Whats the best way of going about removing them from my Mk111 frame. Have tried tentatively to put a hacksawed slot in them with the intention of using a flat screwdriver to 'undo' them.
Indian Interstate tank
For anyone who is interested, I have just this minute ordered a black and gold interstate tank from Vintageindia13. The big delivery date is from 10th March to 20th March. I'll keep this post updated as things progress.
MCR2
Hello,
Does anyone have the service info for an MCR2 regulator (1950) 37097E, or any advice on set up would be much appreciated.
Regards, Bill
Metal adhesive/repair kit
Has anyone any experience of "Delta Quick Steel Repair and Retain" adhesive/repair gel? It's sold by Frost Restoration. I'm interested in it's Adhesive qualities as I cannot weld or braze. Many thanks for any input. George
Damper/stop plate set up
Just reassembled the front forks on my Dommie rebuild, The stop/damper plate under the headstock looks like it needs spacer under it where it bolts to the frame but I can't find a spacer in my box of bits from when I took the bike apart.
ES2 Valve Lifter
Is it possible to get a square type O ring for the valve lifter on a 1954 ES2 ? The groove is quite wide. I have tried 2 o rings side by side but they just break apart and a lot of oil leaks out.
Dominator tank refurb
I would like to have my 88 Dominator tank repainted and was wondering if anyone can recommend a company or person that does this. I have had one quote of £500 which seems excessive to me but maybe that is the norm. Any advice welcome.
Ethanol
There is no Ethanol free petrol without a fair ride near where I live. What Ethanol protection do others use in their fuel?
I have been looking at Millers EPS Ethanol Protection.
What will they put in fuel next? Roger
Indicators on a 99
I have working indicators on the 99 but to fit them I drilled holes in the old headlamp. Now fitting a new shell I would like to mount them on the HL bolts (cycle thread?) Are the parts availiable? Anyone done this?.
16H frame threads
Hi, I have a 1943 16H which arrived in boxes! I'm dry building it and can't seem to find the thread that's used in the frame to secure things like the seat, speedo bracket etc. Is the thread standard through the frame irrespective of the size.
